Oil pan woes
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Oil pan woes
well ive almost got the engine sat in, go to put on the oil pan today, and bgoom.. an inch gap on the rear of the block .. i tried to use the oil pan off my 305 cause i thought it had to be an Fbody oil pan, and someone threw away the pan on the 355 going in it now so im at a stopping point (again
) anyone know what kind of oil pan i can use that will fit in my car and ont he engine, its a pre 80's block i believe 350 4bolt.. any help would be great, i have to have this thing running soon.. been like 6 months w/out a car
thanks for the help fellas.
thanks for the help fellas. you need a pan to fit your block other than that most stock pan will fit the car. only differance in the pans is the front curved area being a differant radius. i'd guess you have a one piece rear seal pan on a two piece seal block.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Ede is right Ben, you also need an oil pan for a 2 piece main seal to go along with the correct flywheel, you should be able to find a cheapie chrome one locally for about 40 bux that will fit fine.
