what engine to swap??
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
i have a 91 305TBI RS. im wanting to do a swap, bigger engine! and ive been leaning tward a buying a 350 and makin a 383 stroker out of it. my quistion is i would be buying this engine used, wat kind of car should i pull it out of?? my first guess would be an older camaro, or corvete? anyone have any suggestions or input with my swap?
also----when did corvetes turn to fuel injection??
Transmission: 4L80E/4L80E
What is your intended use for the car after the swap? Daily driver? Occasional driver and occasional racing? What transmission do you have? Do you intend to keep your TBI fuel injection, or go with TPI, or aftermarket FI, or carb?
Why are you asking about Corvettes?
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: what engine to swap??
Car: 91 Camaro
Engine: LO3 305 TBI
ok, to answer quistions. i use it as a daily driver but also bring it to the track and do some street racin. i dont want a TBI, and would preferbly want FI but heard its hard to wire and stuff, but anyway i was askin about corvette motor bc i think i might get ahold of an 84' corvette engine. would that engine work for my car fairly easy??
Car: '89 Firebird
Engine: 7.0L
Of all the possible Corvette engines to choose from the '84 "crossfire injection" engine is the 2nd least powerful right behind the original blue flame straight 6 from the very first year. I'd look at other years.
Car: 91 Camaro
Engine: LO3 305 TBI
oh damn, well getting a corvette enigne be fairly straight forward install tho?, will it always fit? and would i need the whole wireing harness to do FI??
No.
Almost anything can be made to "fit".
Most likely yes.
Most likely yes.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The first REAL fuel injection system the 'vette got was TPI in 1985.
CeaseFire Injection wasn't much more than a CC 2bbl carb X2, and the old mechanical fuel injection systems were not much different than the truck carbs made now that are made to handle weird angles and G-forces.
And a Corvette engine is basically no different than a Camaro engine externally. The only major difference is the oil pan.
