lt1 timing chain
Old Sep 14, 2004 | 10:39 PM
NoUseAbleNames's Avatar
lt1 timing chain
why is the lt1 chain so much more expensive than that of a l98?? lt1 chains even stock are like 150 bucks. whats the catch??
thanks
Old Sep 15, 2004 | 05:54 PM
David Petersen's Avatar
This is just my understanding but I belive it is beacse the L98 timing chain has been used for so maney more years there is more demand for them thusly they can be made in larger qunaties for more of a discount, where as the LT1 is only used for 5 or so years smaller quanities = larger mfg costs.
Old Sep 15, 2004 | 07:47 PM
ok sounds like it might make sense. the lt has been out for 12 years now. since 92 in vettes, i think it was. or 93 for sure in f bods. is it a stronger chain too??
Old Sep 15, 2004 | 07:53 PM
TexasLT1's Avatar
Car: '92 RS
If that were true and the LT1 chain was the same as the L98 chain, it would be the same price.
Different chain.
Old Sep 15, 2004 | 09:19 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the timing set is 150...the chains themselves are the same...the gear are what makes the lt1 set more money...its becase the cam gear has a gear on the back of it for the water pump.
i know becasue i paid 19 dollars for a cloyes chain for my LT1
Old Sep 15, 2004 | 10:16 PM
were did get that >> did you use your stock gears?
Old Sep 16, 2004 | 12:21 AM
TexasLT1's Avatar
Car: '92 RS
You're right, I was thinking of just the chain, knew the gears were different.
Old Sep 16, 2004 | 10:11 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i got mine at murrays..it our local autostore beside autozone..i know autozone carries them but i think there like 23 24 there...
i reused the gears as they are in working order
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
MY87LT
Aug 17, 2015 08:43 AM
Thirim
Aug 9, 2015 06:19 PM
