Can I use a TPI throttle body on an LT1?
Old Oct 1, 2004 | 11:54 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
May be doing a LT1 swap soon, and have a question. I'll be keeping the 700R4, so can I use the throttle body off my LB9? I'm sure an LT1 throttle body will perform better, but will the LB9 one bolt up for temporary use?
The LT1 is from a 95 Trans Am.
Old Oct 1, 2004 | 12:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
IIRC, the '93 LT1 TB is what you're looking for.
Afraid I can't answer the question about a TPI TB on LT1. Did you check through all the LT1 stickies above?
Old Oct 1, 2004 | 12:16 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
yes the tb is interchangable from 85-97,the LT1 used a different tps(non adjustable) the tps connector is different and the throttle cable is interchangeable from '85-88 and the '89-'97 hope this helps
Old Oct 1, 2004 | 12:34 PM
five7kid's Avatar
I don't have direct experience with LT1's and 4th gens, but didn't the 4L60E come on the scene in '94?
Old Oct 1, 2004 | 03:16 PM
Drakar's Avatar
yes only 93 Fbody TB's had connections for the 700R4/4L60.
the 4L60E was all electronically controlled.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
