383 stroker and stock MAF problem.
Old Oct 29, 2004 | 03:05 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I bought a 1989 GTA with a 383 stroker in it to part out. The MAF was unplugged and I was told that the engine would stall with it plugged in during deceleration. I tested the MAF and was wondering if this is a problem with the compatibility between the stock 350 computer and controls with the 383 stroker?
Thanks,
Jim
Old Oct 29, 2004 | 04:00 PM
Drakar's Avatar
there could be a whole host of problems if the chip is stock and the 383 has anything more then very mild too it.
I would say a custom prom could make the 383 run just fine, normally the maf is a restriction on airflow, and CFM's and so forth, not on decel and stalling, it should actually help that.
Sounds like a chip problem.
Old Oct 29, 2004 | 05:24 PM
Engine: 3.4L 207 V6
Ok, the 383 is probably better than mild. The dyno sheet w/ spray is over 650 hp.
Old Oct 29, 2004 | 09:26 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Sounds like somebody didn't change the maf table or injector constant or idle rpm in the chip, so they by-passed the maf. Typical half-assed way to hotrodding. All it needs is a little chip work.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
nuggie
Aug 25, 2015 01:27 PM
Bert87
Aug 23, 2015 03:50 PM
