need engine swap help quick!
Old Nov 21, 2004 | 07:18 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
ok i need some tech help here, i got a 91 camaro RS that has a 305 TBI, with a cracked block, about the only 305 that we found around here is a 86' vintage 305 that was in a truck, i know that the oil pan will have to be changed, but my big concern is the heads, for now i need to keep the TBI setup, so i'd need to put the TBI intake and heads on this engine, how possable is it to put the 91 heads on a 86 engine
also how hard is it to convert over all the serpentine equipment to this engine, since it has the v belt setup?
Old Nov 21, 2004 | 07:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Unbolting the serpentine and swapping it onto that motor will be quite easy, make sure you also transfer the water pump, heads will change over with no problem also.
Old Nov 22, 2004 | 02:47 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Why not look for a 350? also, an 86 will have a 2 piece rear main seal, and a 91 will have a one piece rear main seal, so you will at least need a new/used flywheel or 2-1 piece adapter for a two piece crank seal.
Old Nov 23, 2004 | 03:53 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Please get your info correct before you post, 86 was 1 piece rms.
Old Nov 24, 2004 | 11:24 PM
White93z34's Avatar
Engine: LB9
can anyone else verify the 1 or 2 piece RMS?
can i just use the flywheel off the 86' engine?
Old Nov 25, 2004 | 12:28 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Just trust me on this one and not the amateur, both are 1 piece, yes you can just leave the flexplate on the 86 if its still there.
Old Nov 25, 2004 | 12:32 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i believe after 85 it was a 1 piece maybe 84 im not to sure but yes 86 is a 1 piece or new gen mtr crank
Old Nov 25, 2004 | 09:32 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
86 was the first year for the 1 piece.......
Old Nov 29, 2004 | 01:26 PM
Engine: 5.7, 5.0
Sorry. 86 was the first year with 1 piece RMS.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
