L03 to L98
Old Feb 22, 2005 | 10:49 AM
tb8125's Avatar
L03 to L98
Here is the thing I have a L03 with a 5 speed manual Borg-Warner transmission (is that the same thing as a T5)
Well the L98 is is for a Automatic vette not sure of the transmission spec. My question is will the flywheel from the L98 work with my 5 speed manual Borg-Warner transmission
If it wont work can I use the flywheel from the LO3 and just press a new bareing in?????
Any suggestion would help thanks want to get the car back together soon thanks
Old Feb 22, 2005 | 01:02 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i did the same swap.. LO3 5 speed to L98.. bolts up fine. the 305 and 350 is basically the same block from an external standpoint.
Old Feb 22, 2005 | 03:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the Vette L98 is '86-later, the flywheel will be the same. If it is '85-earlier, it is different and you'll need to get a two-piece rear main seal 153-tooth unit.
Old Feb 22, 2005 | 03:07 PM
tb8125's Avatar
Its 85
Old Feb 22, 2005 | 03:12 PM
five7kid's Avatar
Now you know. Need different.
Old Feb 28, 2005 | 07:54 AM
tb8125's Avatar
five7kid I found out that the motor is actually 14093638 . ..350...87-95...2 or 4...Roller or flat tappet cam one-piece rear seal i
I already bought the other fly wheel this weekend i tried to put the oilpan on it did not fit I tried to use the one from the 305
Old Feb 28, 2005 | 09:35 AM
five7kid's Avatar
Something sounds pretty weird there.
Old Feb 28, 2005 | 09:40 AM
tb8125's Avatar
Its the oilpump and the splash plate that is keeping the oilpan from fitting can use the oilpump from the 305 will it pump enough volume to a 350
Old Feb 28, 2005 | 09:58 AM
five7kid's Avatar
There shouldn't be any difference between a 305 and a 350 oil pump. I'd at least put a new pump on - a Melling M55 should fit, depending upon what splash plate this is that you're talking about. I don't have a lot of hands-on experience with Vette parts, though, so maybe that's all you're got going on.
Old Feb 28, 2005 | 10:20 AM
tb8125's Avatar
Its not the pump its the pick tube and the splash plate over that. All i have to do is chang the pickup tube??????
Old Feb 28, 2005 | 11:37 AM
five7kid's Avatar
I'd check into that first.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
anesthes
Sep 21, 2015 10:24 AM
