Only the 1-3-5-7 bank is priming with oil.....
Old Mar 19, 2005 | 12:12 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Well i finished the long block this morning. Went to prime the engine with an old distributor shaft and drill like i always have. Now in the 3 years since ive been outta school and builing engines ive never seen this happen. Only the 1-3-5-7 bank had oil coming outta the pushrods onto the rockers. The 2-4-6-8 Bank had NOTHING. I sat there with the drill for a good hour and didnt get ANYTHING . A couple times i got a couple drips of oil outta the exhaust rockers on 2 and 6 but that was it. Any suggestions?
Old Mar 19, 2005 | 03:41 PM
Gary Anderson's Avatar
Did you try turning the motor at all?
Gary Anderson
Old Mar 19, 2005 | 04:32 PM
Transmission: th350
Yup several times. I mean the one bank came up right away, and nothing outta the other....weird. I think im gonna throw a 1/2 drill on it, or just fire it up and hope for the best.
Old Mar 19, 2005 | 07:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is the distributor shaft sitting down in the bore properly around the oill passage?
Old Mar 19, 2005 | 07:20 PM
Transmission: th350
Dist shaft aroudn the oil passage? huh? Dude the dist shaft fits around the oil pump shaft. And yes its aorudn it and ye sim showing 50psi on my mech gauge.
Old Mar 19, 2005 | 07:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you using just a distributor shaft, or do you have the shaft housing too? The oil passage to the right bank goes through the distributor bore, without anything there, oil will just drain back down to the pan.
Old Mar 19, 2005 | 07:59 PM
Transmission: th350
I was just using a shaft, hahaha ive never used a housing before but damn it makes sense. I wonder why ive never ran into this problem before.
Old Mar 25, 2005 | 05:53 PM
BOTTLEDZ28's Avatar
Transmission: A4
you know what I find works real good, a compressed air tank like the ones used to spray pesticides on weeds and stuff. I have one that looks just like a propane tank but the top comes off and I fill it with 7 qts of oil. I then seal the top and pump it up. There is a hose with a trigger on it and I connect the end of the hose to the hole on the back of the block(rear china wall) once I hit the trigger, the oil is compressed into the block and you can actually hear the air being displaced out. It takes about 3 minutes for oil to come shooting out of the rocker areas.
Old Mar 25, 2005 | 06:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I remember reading in poip hotrodding or car craft that there is a pipe plug in teh back that needs to be put in otherwise one bank of cylinders willnot get oil. Poncho blocks are the same. I gotta see if I stillhave that issue, it was on street combos for 9.5:1 compression.
Waas you block hot tanked or machined any??????
Old Mar 26, 2005 | 01:10 AM
Transmission: th350
Yeah it was machined and hot tanked. I stuck an old housing in minus the drive gear and it primed perfectly.
InfernalVortex
Apr 20, 2021 11:31 AM
xodus2002
Jul 17, 2020 09:08 AM
gta892000
Aug 11, 2019 11:16 AM
RS Reaper
Oct 17, 2018 07:52 PM
86Firebird86
Dec 26, 2015 07:21 AM
