BBC power estimates?
Old Apr 27, 2005 | 04:22 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
I may be buying another big block soon. Right now the motor has some sort of GM big block head (unsure of head) flat top forged 10:1 pistons, 4 bolt mains etc etc.
Now if I buy it I am going to put in a hydraulic roller cam (234/242, .610/.632, dart iron eagle 308cc, 119cc combustion chamber, 2.250/1.880 valves, matching dart single plain intake, and a dominator carb. I was thinking about the 750 dominator, unless I can handle a real dominator with that set up
so what do you guys think that kind of set up would put down for numbers? When all is said and done I may spray it with a 150 shot. I am still undecided what kind of car this is going in, but I really have the urge to build a new motor
Old Apr 27, 2005 | 06:36 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Thats a pretty weak cam for a big block....
Old Apr 27, 2005 | 07:33 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
what about a 244/256@.050 with .632 lift intake and exhaust? I am in the dark with big block cams.
what about the ccomp cam that switches the 4 an 7 cylenders. has 279/282 with .714/.680 lift.
summit has a cam I was also looking into. summit PN CRN-138871
that first cam decision was based on not wanting to rev too high. I doubt big blocks like to scream to 7500 all the time.
Old Apr 27, 2005 | 07:57 PM
pasky's Avatar
How many CI's will the block have and what will the heads flow? Drag or street?
Old Apr 27, 2005 | 08:13 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
454. I am not to sure what the heads flow. They will most likely be box stock...I guess I can search around for flow #'s.
Old Apr 27, 2005 | 08:16 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
and is there any point when I would have to worry about piston to valve clearance?
Old Apr 28, 2005 | 02:36 AM
pasky's Avatar
Not sure on that the piston to valve clearance, might want to speak to a professional on that issue or someone else could chime in.
Thing is im running a 230/244 .544/.574 on my 383. I was running the same cam in my 350 and it was plenty streetable. You have over 154 more cubes, that one you first picked would be quite mild.
I suggest something in the range of 260/268 .510 / .540 @ 0.50 on a 112 LSA
Will have a nice idle and will not need to be revved to the moon to make power.
Old Apr 28, 2005 | 12:27 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
I was thinking I might stick with a 110LSA or possibly a 108 depending on the grind. I can care less about idle quality, and don't mind not so great driveability. I want to make maximum power without revving too high.
Old Apr 28, 2005 | 12:32 PM
pasky's Avatar
Well usually the lower the LSA the higher you will rev because there is more valve overlap which is why I suggested the 112 LSA. If you want the 110 or 108 lsa, look in the range of a 248/258 cam with a .510 .540 lift.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
