wiring madness
Old May 12, 2005 | 09:12 PM
cody mcguire's Avatar
Car: 89 rs camaro
Engine: tpi 355
Transmission: th350 manual valve body
wiring madness
sup chevy freaks
I still working on my swap, i split the camaro engine compartment harness from the ecm. I have a few wires that i suspect need to go back to the ecm harness i.e. a black/pink and a green/wht. I think I need to get a harness from an iroc for under the dash from the ecm to the dash but im not to sure on what i need to do there. The engine is out of an 87 firebird,I unplugged the harness from the bulkhead. Ive since did the necessary trimmings to get rid of the plug. Now everything will go together, except i may or may not need some info on the wiring going back to the ecm,or coming from the ecm
Old May 12, 2005 | 09:17 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
And your question is.....
Old May 12, 2005 | 11:29 PM
Car: 89 rs camaro
Engine: tpi 355
will my plan work? i found a thread with the harness layout to the ecm. i guess ill have to figure it out, some input would be very helpful
Old May 13, 2005 | 06:56 AM
Lo-tec's Avatar
What engine are you removing, and what are your putting in it's place? The "engine harness" that goes to the ecm should come out pretty much in one piece, leaving a separate harness for gauges, alt etc. still under the hood.
Out-Cast
Mar 22, 2019 09:39 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Wade787b
Sep 29, 2015 01:15 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
