PolicE CapRice.350
Old Jul 7, 2005 | 01:33 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
PolicE CapRice.350
Hey
I went to a junkyard today and found a police Interceptor w/ a 350 out of a caprice.What is Hp Rating on those. its a TBI. I cant find any information on it. AnyHelp would be great.
They wanted 320.00$
Old Jul 7, 2005 | 10:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Something in the 200 range.
"Police" means nothing, except a lot of idling time and probably high, and hard, miles. It's a run-of-the-mill LO5, which could yield a good shortblock, but don't even consider a performance intake and cam with those swirlport heads.
The TB is worth something to someone upgrading their LO3 to a 350.
Old Jul 8, 2005 | 11:02 PM
Not worth it huh?,
Doesn't have the vortex heads?
Old Jul 8, 2005 | 11:06 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Originally posted by 84RIceEater
Not worth it huh?,
No,it won't have vortec heads,those did not go into production until 1996.The heads appear similar from the outside,but vortec heads only have 8 intake bolts as opposed to 12 on the early style.
Old Jul 12, 2005 | 11:30 PM
ahhh... so better not get it because its a police car that has suffered alot of stop and go and high abuse, and get a normal everyday 350?
Old Jul 13, 2005 | 08:56 AM
five7kid's Avatar
It depends upon the particular department, but most police vehicles are well maintained in spite of the hard use. It's probably a good shortblock core, just don't expect to install it as-is with a mongo cam and go 11's with it.
Old Jul 13, 2005 | 10:58 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Ford made Police Interceptors, Chevy didn't.
The engine is an LO5 from a 9C1 police package Caprice. The model year is somewhere in 89-93 with the TBI.
The specs on it, along with the differences with the other two LO5 engines (truck, car) are in earlier posts and the engine power/torque specs depend on the model year (injectors, cam, lifters and tuning are different so the hp/torque are also different).
Do a search on LO5 and 9C1 and you'll find what you need.
Old Jul 14, 2005 | 12:50 AM
i am just planning on using it as a daily driver. Just somthing better than the 305. maybe once or twice every six months i would take it to the track.i would just install a small simple cam,intake and polish the heads.and drive it back and forth to work and school.
Old Jul 14, 2005 | 01:32 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i'd say 320 may be abit much
Old Jul 14, 2005 | 09:07 AM
five7kid's Avatar
Go through your 305 heads, including 1.94" intake valves and the aforementioned polishing (bowl blending would be more beneficial), new valve springs, pinned rocker studs; put them on the 350 shortblock with your intake & a new cam, you'd have a nice runner.
Forget the LO5 heads. They aren't worth the trouble.
Old Jul 14, 2005 | 03:57 PM
kdrolt's Avatar
Engine: LO3, LO5
Maybe not. Porting is a good learning experience, and you will gain performance no matter what heads you have (305 or 350 btw). Just because someone here tells you to forget them doesn't mean they're always right. Do a search on porting 193 casting and you can decide for yourself.
If it's a matter of money, working on your 305 is a fine idea too. I'm not married to either, both have been made to work especially if it's DIY.
If you do stick with the 305 heads, and port them, tradeoff the cost of installing the larger valves against the need for deshrouding them. They won't flow any better than the stock valves UNLESS you remove metal from the chamber. Other people here have shown that bigger isn't always better when working 305 heads over, but porting always helps.
Old Jul 19, 2005 | 03:47 PM
mikey72's Avatar
not all police cars a beaten to death i have a 91TBI and it runs just fine like in a earlier post some departments rebuild the engines and they never usually go above 140000mi before rebuilding
Vintageracer
Jan 10, 2020 05:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
killer305
Nov 3, 2001 07:14 PM
un4givin89
Oct 10, 2001 09:20 AM
rsilver
Oct 7, 2000 03:28 PM
