TPI engine Connectors
Old Jul 11, 2005 | 02:39 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I know this does not seem to be directly related to an engine swap, however due to a poor previous engine swap by a FORMER owner I am in need of several connector ends. It seems that a shade tree mechanic should not be working on cars. He broke off almost every connector clip that goes on the engine .
If you have a better place for this thread shoot me there, thanks...
I am in need of some plug ends, or pig tails, whatever is out there. The ones I know for sure at this point are the IAC plug, the TPS plug, the ECM temp sensor plug... more to come I am sure but I am just scratching the surface.
I tried Painless Wiring, and they said that they do not sell just the ends jsut the assembly, what a Pain.
Any help would be appreciated.
Old Jul 11, 2005 | 02:47 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Junkyard is the only place I know of. I'm trying to get wiring for a MAP sensor.
Old Jul 11, 2005 | 04:01 PM
okfoz's Avatar
yup I am finding that too...
anyone get anything aftermarket?
John
Old Jul 11, 2005 | 04:37 PM
kevinc's Avatar
Car: 1982 Z28
PepBoys has quite a few connectors in the Electrical aisle hanging on the shelf.
Dealers can usually get them but the $$ is pretty bad.
Junkyard is my favorite option.
Old Jul 11, 2005 | 08:21 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
We carry some pigtails at the shop. Its a Parts Plus store, so if ya go thier website, ya might be able to find one near you.
Old Jul 12, 2005 | 03:50 PM
MiikeS's Avatar
Two places:
http://stores.ebay.com/TPI-PARTS
http://rosesandwrenches.com/home/
Should be able to find all you need. I did.
Old Jul 14, 2005 | 08:00 AM
okfoz's Avatar
Thanks Mike
John
Old Jul 14, 2005 | 08:18 AM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Also try Yearone also. http://www.yearone.com/serverfiles/f...ain2.asp?cat=G They sells them also.
Old Jul 25, 2005 | 11:52 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
NAPA carries more electrical connectors than you would believe. The Echlin line they carry has almost all the connectors for the underhood connections. The two I know they don't sell is the firewall bulkhead(C100) and the heater resistor plug for non A/C cars.
Old Jul 25, 2005 | 12:11 PM
okfoz's Avatar
I got some at a local 'yard... Fortunately GM was smart enough to use universal plugs for late 80's cars... The ones I needed IAC, TPS, and ECM coolant temp I got from an 88 1500 Truck.
I knew the owner so they were "FREE!"
can't beat that with a stick.
John
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
