2 Bolt or 4 Bolt?
Old Jul 21, 2005 | 02:07 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
2 Bolt or 4 Bolt?
What exactly is the difference between a 2 bolt and a 4 bolt engine and how can i tell what my engine is?
Old Jul 21, 2005 | 02:28 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
its the number of bolts on the main caps. except the front and rear caps which all have 2. If you have a 305 like the signiture says you have 2 bolt main. all 305s where 2 bolt main.
Old Jul 21, 2005 | 02:32 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
I want to drop a 350 in my car. Do they come in 2 bolt? Also is a 4 bolt better then a 2 bolt?
Old Jul 21, 2005 | 02:35 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
4 bolt would be better, but there were alot of hi performance small blocks built before 4 bolts mains were invented. If you can find a 4 bolt block it would be better. It really depends on how much power you want to make. A 2 bolt main would be fine, especially if it a mostly stock motor with a few mods. My 406 sbc is a 2 bolt main and its probably close to 500 hp.
Old Jul 21, 2005 | 02:45 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Would I have to do any modifications to put a 4 bolt engine into my car which apparently has a 2 bolt?
Old Jul 21, 2005 | 02:54 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
no....all small blocks have the same motor mounts and transmission bellhousing pattern.
Old Jul 21, 2005 | 03:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
For anything you're going to do on the street, it doesn't matter. For a real performance build, a 2 bolt block is better so you can machine it for splayed 4 bolt caps.
Old Jul 21, 2005 | 07:28 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
you have mail bro
Old Jul 26, 2005 | 08:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You wont need to worry about having a 4-bolt block over a 2-bolt block unless you are making well over 400hp. Even then, a factory 4-bolt block isn't much stronger than the 2-bolt block, so it doesn't really matter that much. If you really need to worry about that, then you should buy a 2-bolt block and have it machined for aftermarket (splayed) 4-bolt caps. They are MUCH stronger than the 4-bolt factory caps.
Old Jul 26, 2005 | 09:50 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
This is a 4 bolt block.
Old Jul 26, 2005 | 09:52 PM
AJ_92RS's Avatar
This is a 2 bolt
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
