VETTE MOTOR swap problem in IROC
Car: 02 Z28, 78 Z28, 86 Iroc
Engine: 346 LS1, 350 Goodwrench, Vette 350
Transmission: M6, T 10, 700 R4
I just pulled off the oil pan from the 87 vette motor and went to put on the camaro pan from a 88 iroc 305 and it will not fit. The catch is hitting the pan. So now either 350 and 305 pans are different or the corvette oil catch is bigger then a camaro and I will have to get a camaro oil pump. What really sucks is i work 7 days a week and i had to take sunday off to put this in and now it looks like im **** out of luck for getting it in tomarow.. If anyone know what exzactly i need please help cause i have to get this in. Im swapping a 87 vette motor in my 86 iroc.
yea i just figured out i have to change the oil pump so everything vette has to be changed over to camaro
Just sucks cause i just have till tomarow to change everything over and drop it in. Im guessing i have to change splash covers to from the camaro. Im gona be needing parts to like the oil cooler lines that go from water pump to cooler mine are busted. I got to get sleep now i have to search these parts from my buddies just a matter of time now
Just sucks cause i just have till tomarow to change everything over and drop it in. Im guessing i have to change splash covers to from the camaro. Im gona be needing parts to like the oil cooler lines that go from water pump to cooler mine are busted. I got to get sleep now i have to search these parts from my buddies just a matter of time now TGO Supporter
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The oil pump pickup is different between the Corvette and Camaro engines. Thats why the Camaro pan will not fit onto the Corvette engine.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The big difference is the baffles in the pan, the pickup, and more importantly the windage tray and studs. The studs contact the fbody pan. I tried swapping my stuff last night (buddy wants the stock vette motor for his fbody) and the fbody pan won't fit with the studs in place. I gotta go find 3 main cap bolts for 2 bolt main and 3 studs for mine. heh. lame.
-- Joe
Car: 84 Trans Am
Yea, the 350 I'm putting in my TA had a windage tray so I couldn't get the 305 oil pan to fit. But luckily my buddy had a 350 that had thrown a rod sitting in the garage and we just swapped the mains, so he got my windage tray and the oil pan that worked with the windage tray.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
theshackle
Mar 5, 2017 06:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
