thinking about swap
Old Nov 5, 2005 | 06:54 PM
Blkmaroman's Avatar
Car: 1998 zx9r
Engine: 899CC inline 4
Transmission: 6 speed manual
Axle/Gears: 15T front sprocket, 43T rear
thinking about swap
i have an 86 iroc, and i recently put in a 355, but i was thinking about going to an lt1. I am getting a job making 19 an hour so i l will have money. I want to get an lt1 turn it into a 383 and put on the lt4 swap stuf should be pretty stout. And i have to get painless wiring to wire it up. But what all am i going to run into as far as tranny and small stuff. I want to run a 700r4 with a mechanical speedo. Will the motor need anything signals from the tranny if i get the painless wiring harness.
Old Nov 21, 2005 | 09:43 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
You'll be fine using a 700R4 that has the mechanical speedo setup. You will have to buy a vss converter that will splice into the speedo cable to give the computer a speed referrence. Other than that, everything will bolt up like it should. Also, make sure you have the pcm reprogrammed for a 6-speed car. This will save you from setting codes from the computer not seeing the trans. If you have any other questions or need parts, let me know. I just finished my dad's swap of a 95 LT1 in his 86Z.
Old Nov 21, 2005 | 10:03 PM
Firebat's Avatar
1981LT1, did you install a 700R4 with a LT1? My main problem is the TCC.
Blkmaroman, there are better/cheaper performance upgrades that you can do other than a LT4 kit. Look into the LE1, LE2, or LE3 kits. These are mentioned a lot at camaroz28.com, which is a good source for 4th gen stuff.
If you get a 93 LT1, you will have no problem hooking up a 700R4. However, the 95 seems to be the best LT1 to get but you can't always choose what you find.
You probably wont need the painless wiring kit. If you use the LT1 wires that is. Might as well save a few hundred bucks.
Old Nov 21, 2005 | 10:14 PM
1981LT1's Avatar
Engine: LT1; LT1
yes i used the 700r4. I bought a TCC lockup kit and spliced in into the brakelight switch. I guess I should have mentioned that too.
Old Nov 21, 2005 | 10:32 PM
Firebat's Avatar
what brand did you get and how well did it function?
Old Nov 21, 2005 | 10:54 PM
1981LT1's Avatar
Engine: LT1; LT1
It was from www.speedscenewiring.com. I think they charged me $65. You can also get one from mr gasket or do a google search for 700r4 lockup kit. It does the same the thing the computer does when in operation. The only thing to worry about is whether the TCC pressure switch is normally closed or normally open. you will be able to tell this when you take off and the trans seems like it is already in overdrive because the coverter is locked. All you have to do is switch the wires on the relay. The instructions that come with the kit will explain all this.
Old Nov 21, 2005 | 11:03 PM
Firebat's Avatar
i know how it functions. what i meant was how well did it work. Did it seem normal? Some people have complained about lock-up kits.
Old Nov 21, 2005 | 11:09 PM
1981LT1's Avatar
Engine: LT1; LT1
I can't tell anything different.
Old Nov 22, 2005 | 08:57 AM
Blkmaroman's Avatar
Car: 1998 zx9r
i appretiate the responses. The more info i gather now, the better off i will be later.
customblackbird
Aug 15, 2021 10:16 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
