Carb swap...Hood fitting?
Old Nov 22, 2005 | 02:15 PM
Franchise's Avatar
Hey,
I have a '91 bird, and everything won't fit. I have a Q-jet and Edlebrock intake.
Does anyone, who did a EFI to Carb swap, still able to fit everything with their stock hood?
Without cutting or going cowl that is.
Thanks,
Franchise
Old Nov 22, 2005 | 02:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If you didn't go with an intake that was the same height as a stock 4bbl intake that was on the 305's, no it won't fit, espeically if you had to run a carb adapter plate for the q-jet to bolt to the Edelbrock. There wasn't alot of room to begin with.
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
Yes, i swapped and didnt have any problems with hood clearance. I have the edelbrock performer intake with a Holley carb. I was told that if i were to buy the performer rpm manifold that it would create hood clearance issues due to it being naturally taller. Which manifold are you running? My air cleaner doesnt even contact the hood. I believe that there is almost a half an inch between it and the hood. -Bob
Old Nov 23, 2005 | 08:15 AM
Franchise's Avatar
I thought I had the performer...but will check on turkey day or at least by the weekend, since my car is stored somewhere else.
Thanks guys, I will let you know.
Franchise
Old Nov 23, 2005 | 11:59 AM
Franchise's Avatar
I have an Edelbrock Performer. With the Q-jet on it is extremely close, the adapter is mayber 1/8" thick.
What size air cleaner did you use?
Was it the Edelbrock street....it is the foam one?
Thanks,
Ron aka Franchise
Old Nov 23, 2005 | 03:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Something isn't adding up here. No adapter is required to put a q-jet on a Performer intake. And, 1/8" is too thin to be an adapter.
You will need a drop base type air cleaner. Even the factory stock air cleaners are drop base.
Old Nov 24, 2005 | 11:58 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It fits. read this thread
https://www.thirdgen.org/techbb2/sho...&highlight=L88
Old Nov 24, 2005 | 07:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by Klortho
If you didn't go with an intake that was the same height as a stock 4bbl intake that was on the 305's, no it won't fit.
Thats not necessarily true... A friend of mine is running an Edelbrock RPM air gap, demon 4bbl, and 14x3 drop base in an '86 Trans Am and it all fits just fine under a stock hood. Thats quite a bit taller than a stock 4bbl setup.
Old Nov 24, 2005 | 09:23 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
Edelbrock 7101 (Performer RPM Air Gap)
Holley 3310
and a K&N 60-1280 air cleaner should fit under a stock hood.
Old Nov 26, 2005 | 03:01 PM
Franchise's Avatar
Guys,
Thanks for the info. I am going to look into it the next few days.
I will keep posted.
later,
Franchise
Old Nov 28, 2005 | 10:31 PM
Egg83's Avatar
Car: 85 Firebird
Ah, I forgot to mention that I have a drop base air cleaner. Thanks for catching that five7kid. -Bob
Old Nov 29, 2005 | 10:41 AM
Franchise's Avatar
Thanks for the advice.
Anyone have an extra drop base?????
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
matthew911
Aug 12, 2015 09:38 AM
