Depth of Drop? from Drop Base Air Cleaner?
Old Dec 5, 2005 | 10:24 AM
Franchise's Avatar
Hey guys,
I need a drop base air cleaner after my engine swap to a SBC.
I know I need a drop base, and know what they look like, but how much drop would you say is there? (in inches or so)
since it surrounds the carb. A guy on ebay says his is a drop base, but it is only 5/8"----that doesnt seem like enouch....
(to check it...just search drop base ac on ebay)
what do you think??
Thanks,
Franchise
Old Dec 5, 2005 | 12:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The open style I had was about 1-1/4" from the air horn air cleaner mount to the bottom of the filter elemet.
Old Dec 6, 2005 | 12:45 PM
Franchise's Avatar
hey five7,
thanks for the reply....so a drop of 1 1/4" is the depth.
OK...this guy said it was like 5/8". I thought that was too little.
Thanks,
Franchise
Old Dec 6, 2005 | 02:21 PM
five7kid's Avatar
I never did a rigorous measurement to determine final clearance. However, I believe the hold down nut stayed out of the hood blanket.
I've heard 'Bird hoods come a little closer to the engine than Camaro hoods do, but no evidence to support that.
Old Dec 6, 2005 | 02:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's something that you'll have to try several of after the motor is in - it will all depend on the carb and (mostly) intake used. After I put in my 350 with a Performer RPM and Edelbrock 1405, I went through 3-4 different air cleaners from different places before I found a fit. I ended up with a drop base about 1 1/4 inches, but it wouldn't clear the linkage, so I had to get a 1/2 inch plastic riser, and then go with a 2 1/2 inch element to get it to fit. It just barely pushes up a tad on the hood when it's shut - but it fits, and saved me the expense of a cowl hood for now.
Old Dec 7, 2005 | 01:32 PM
Franchise's Avatar
thanks five7.
Hey camaronewbie,
where did you get your final drop base from?
ALSO, you guys think 7/8" of a drop is enough?...that is the deepest I have found.
Thanks,
Franchise
Old Dec 7, 2005 | 04:52 PM
Car: 1992 RS
Engine: Carbed 350
I was trying to remember where, when I wrote before - brain dead here. I'm pretty sure it was a no-brand from Pep Boys. Might have been a Mr. Gasket - I can't remember. It was deep, and had indents for linkage/choke - but the indents didn't match up - thus the 1/2 inch plastic spacer and then 1/2 inch shorter element. Like I said, you'll just have to wait until motor in and complete, and try a few - just save receipts for returns!
I also did new poly motor mounts - which changed things a tad from the old sagging mounts.
Oh - and you can compare intake heights at edelbrock.com - they have heights listed for each manifold.
Old Dec 13, 2005 | 08:49 AM
Franchise's Avatar
Thanks for the info.
Old Dec 15, 2005 | 08:15 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I've got a victor jr intake, 1/2" nos plate, and a holley carb and it all fits under my stock hood with this air cleaner. I bought it just to see if it fits and what kinda drop I would need, but I like it http://go.mrgasket.com/ProductDetail...&minselection=
Old Dec 16, 2005 | 06:57 PM
Franchise's Avatar
hey 85z28,
I tried to access the page you posted, but I get an error.
Can you tell me the make/model....or better yet the part #???
Thanks,
Franchise
Old Dec 16, 2005 | 07:31 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Originally posted by Franchise
hey 85z28,
Thanks,
Franchise
Its mr.gasket part number 9790. Its called "Competiton air cleaner". Its 14" by 3". Its was like $40 with the air filter, stud, and wing nut
Old Dec 18, 2005 | 03:25 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I got mine from summit I think it was $35 and it came with what looks like a K&N. But I dont think it is.
Old Dec 19, 2005 | 10:01 AM
Franchise's Avatar
Thanks guys...I will check it out.
Anyone been to autozone lately...it looks like a drop base a/c, about $30, with everything.....just an off brand. Anyone check it out?
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
