305 to old 350..will serp brackets work
Old Jan 1, 2006 | 10:33 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i have a 92 rs 305 and am building a '76 model 350 and was wondering if all the serpentine brackets will bolt on and line up..I want it to have a stock look...i am going back tbi to stick with "stock"theme....thanks
Old Jan 2, 2006 | 05:03 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
no. the older style heads <unless you use newer style heads> will not allow it to bolt up. i have forgotten which accessory is on this bracet. but the passenger side head will require 3 bolt holes. and well the older style heads only had 2 i believe. i think everything else bolts up but this one bracet. the two bolt holes will line up with the bracket but however there is no third bolt hole to hold this accessory=\
or atleast in my past experience it didnt work=\
Old Jan 2, 2006 | 05:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It should work just fine. I just dropped a 1969 350 block in my 1992 with mid-70's heads and my stock serp set-up. Just look at the heads and make sure you have the accessory holes. There may be one hole missing in the 1970's heads, but I've done this on 2 cars with no problems. It's the 1960's heads that didn't have the bolt holes for accessories.
And you'll like the 350 SO MUCH BETTER!!!
Old Jan 2, 2006 | 11:55 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
so what do you do about that third bolt? Do you just omit it?
Old Jan 3, 2006 | 10:26 AM
xomega's Avatar
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
i wouldnt forget bout it if it wasnt there=\ those brackets i believe are aluminum
Old Jan 3, 2006 | 12:51 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I have a 92 RS that I swapped a ZZ4 crate engine into. The crate engine heads/block are designed to work with 1970s era and older cars.
All I had to do was drill and tap a hole in the passenger side head. It is the top most bolt hole towards the center of the engine. Worked great. It looks exactly like stock except for the Aluminum heads
BTW the depth of the hole I made match the depth of the other existing holes. This worked fine for the ZZ4 heads, didn't hit any water or intake/exhaust passages.
Old Jan 3, 2006 | 07:21 PM
dwillis's Avatar
Axle/Gears: 3:08
i'll have to select my heads carefully then i assume...i appreciate all the input that has been one of my main worries because i want it to look as stock as i can
Old Jan 6, 2006 | 01:58 PM
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
I have an 86 305 Tpi in my 92rs it had the v-belt pulley, to convert to the serpentine I just drilled and tapped the head. It did however go into the water jacket so I put some Loc-Tite on and havent had a single leak or cooling issue in the 1 1/2 yrs since.
Good Luck
Will
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
Catcher55
Aug 15, 2015 07:08 PM
rh76camaro
Aug 15, 2015 12:48 PM
jahblah
Aug 12, 2015 05:54 PM
