Moroso 6 Qt. Oil Pan
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Thats the oil pan I'm using. It hangs about even with the stock k-member or slightly higher.
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Moroso 6 Qt. Oil Pan
Old topic but..
Do I need to buy Moroso Oil Pickup? Its under required parts at Summit,
but I have already bought Melling oil pickup..?
Also the Windage tray..? Should I buy it..? Or can I reuse my stock one (if there is any) ?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The oil pan pickup needs to be about 3/8" off the bottom of the pan. If you get a deeper pan, you need a longer pickup to reach to the bottom. No sense having more oil in the pan if you can't use it all. At high rpm like at the end of the dragstrip, all the oil can be in the top of the engine.
However, most street vehicles don't need more oil than what a stock pan supplies.
The biggest reason to use an extra capacity pan is to move the oil away from the crankshaft. You put a 6 quart pan on and fill it with 5 quarts. Remark the full level on the dipstick and only run 5 quarts. All that oil now sits in the sump instead of the entire length of the pan which can be whipped up by the crankshaft.
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
I just want to buy new Oil Pan that will clear stroker and becopuose my old on is a bit fatigued thats it
I assume from what you have said that I do need Moroso Oil Pickup.. But still I dont know what about wintage tray..
Car: 87 IROC L98
I don't bother with a windage tray. I just keep my oil low in the sump away from the crankshaft. I run a 7 quart on my BBC but have less than 6 quarts in it. If for any reason the pan starts to get sucked dry, I have a 3 quart accumulator as a backup oil supply until the oil can drain back down into the pan.
