305 tPi to a 406??
Old Jan 22, 2006 | 08:27 PM
nesqwick_05's Avatar
Car: 87 transam
305 tPi to a 406??
how would i got about swapping my 305 tpi to a 406?? i needa know all i can, also could i keep my 700r4 tranny behind it or wut?? LMK cuz im in dire need of assitance here...
Old Jan 22, 2006 | 08:28 PM
Car: 87 transam
this is my first swap.... maybe some1 could walk me through it
Old Jan 22, 2006 | 10:16 PM
ljnowell's Avatar
Location (Emissions)? $$$ to spend? Preferences? Usage?
Old Jan 23, 2006 | 04:15 PM
Car: 87 transam
i wanna keep the cost of the entire set up on tha motor under 1000, tha motor will cost me around 300(short block). wut all would i need to make it complete?
Old Jan 23, 2006 | 04:31 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
A lot more money
Old Jan 23, 2006 | 04:34 PM
Car: 87 transam
figured...
but wut about going carbed?
Old Jan 23, 2006 | 04:38 PM
Car: 87 transam
400 bored 30 over, kb 9.1 pistons, stock crank and rods, flywheel, balancer, new oil pump, new rings, clevite bearings, new freeze plugs. needs honed
Old Jan 23, 2006 | 05:38 PM
ljnowell's Avatar
You need heads, and not just any old heads either. You could make it run with a set of crap smogger 882's or 993's. It wont be worth a crap though. You could probably get by with some really ported L98 heads, maybe open the chambers up a little. You will need a new intake. A new distributor, stocker will work but you will need a good coil, module, etc. Headers. Spark plugs and wires. Gasket kit. Oil. Antifreeze. Cam and lifters. The list goes on and on.
I wouldnt attempt what you are without a lot more money.
Old Jan 23, 2006 | 05:39 PM
ljnowell's Avatar
hey general, whats happening?
Old Jan 23, 2006 | 07:50 PM
antscrd's Avatar
Car: 91 z28/2014 charger
Engine: 350/ v6
Transmission: 700r4/ auto
you'll need gas also.
j/k, but do a and you'll find TONS of info. it will take you as long to read through all the info as it takes to save the ton of money you'll need to git 'er done
Old Jan 23, 2006 | 08:35 PM
Car: 87 transam
well could i get a list of everything i will need?? or are yall clueless lol
Old Jan 24, 2006 | 02:42 PM
ljnowell's Avatar
Search. If you dont want to take the time to research, why should we?
Old Jan 24, 2006 | 03:59 PM
Car: 87 transam
i already did and didnt find nuttin. if i did find somthin i wouldnt be asking
Old Jan 24, 2006 | 10:23 PM
THEGENERAL's Avatar
asking like that is not going to get you any help real quick ...LOL
Okay so what is the exact question you are trying to ask us ?? is it what should I put in my engine? or is it how do I build an engine ? or is it tell me what you think I should put in this engine ??
do you kind of see the problem here...
Old Jan 25, 2006 | 05:34 AM
ljnowell's Avatar
I believe he is looking for an exact rundown of everything he needs to get this engine swap done. Its Pretty basic to find. The reason I said what I did is because he would benefit greatly from reading the past posts on this. Its a long list, and no one wants to take the time to type out something like that, that could be found by searching.
Old Jan 25, 2006 | 08:47 PM
THEGENERAL's Avatar
yeah but searching is too hard for some people.....LOL
Old Jan 25, 2006 | 09:20 PM
ljnowell's Avatar
I forgot.
Old Jan 25, 2006 | 09:50 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I SBC is a SBC they are the same size.
This might give you an idea. On my build up
My short block cost me ~$3500
418 is made up of:
The block .020 over 4-bolt main 400" Chevrolet block
4.145” finished bore.
3.875" stroke
4340 steel Summit crankshaft.
6" Eagle H-beam
4340 stroker rods
Custom JE flat top pistons
ARP main studs.
The timing chain has a needle Torrington thrust bearing
Cam button set to zero lash.
Hardened steel oil pump drive.
There are over 40 machine shop hours in grinding relief for the rods and crank.
Deep notches along and below the oil pan rail.
There is additional clearance at the bottom of the cylinder bores.
The crank and rod journals are standard size.
The bore is fresh and the pistons & rings are new.
ARP main studs, diamond stripper windage tray
and 4-bolt main block.
The block clearance required for the 3 7/8" stroke crank,
beautifully finished H-beam rods and ARP rod bolts.
The high-volume pump has the pick-up tube
Welded to the body for additional durability.
__________________________________________
I bought to run a roller block
Retro Cam/ Small base - Comp Cams230/236 114 LSA
Retro Lifters – Comp Cams
Heads – AFR 195 72cc heads
Crane Gold Roller Rocker 1.6
ARP Rocker Studs
ARP Heads studs and bolts
Trick Flow Push rods
Trick Flow Rocker nuts
Fully ported Super Ram
Fluid damper
Accel Distrubuitor
Accel Fully Port Super Ram
BBK Fuel Pressure Adjuster
36 lbs injectors
Prominator
______________________________________________
The 700R4 will connect to it using a 168 tooth flexplate.
Sice your using a 168 flexplate you will need a different starter.
(Stock starter is 153 tooth)
Did I change you mind yet ???
This does not include a tune....
Old Jan 26, 2006 | 03:59 PM
Car: 87 transam
well i guess my real question is how to build it.... wut all would go in the build of a motor
Old Jan 26, 2006 | 05:00 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
When I got my short block. I had an engine builder tear now and put back together for $300. He double checked the work that was done to the motor.
If you have the skill set and if you have the tools. You can build it yourself. Excluding the machine work if need....
Old Jan 30, 2006 | 09:15 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
That question is best answered by the engine builder/ machinist. It is not as simple as buying a set of wheels and tires. You need a plan. Things work out much cheaper in the end. Fuel quality, intended usage(street, drag, road race etc), emmisions all factor in. Talk to a pro.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
