305 to 350
Old Feb 17, 2006 | 04:33 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
305 to 350
are 305 and 350 blocks interchangable.. i have been told both ways and i just want to know the real answere
Old Feb 17, 2006 | 05:35 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
don't really understand the question but, if you're asking if the outside dimensions are the same then the answer is yes. a small block chevy is a small block chevy be it 305-350 ext.
You're lose would be roughly a 1/4 in loss in diameter of the cylinder bored being 3.740 on a 305 and 4.00 on a 350..... Strokes are both the same at 3.48 i think..... anyways you're losing 45 cubic inches of bore with a 305.
Definetly a big loss in displacement and a pretty good restriction for flowing higher hp through a 305. Although there are many 300+hp 305s and they are plenty easy to make 300hp out of with the right cam and a ported set of heads.
is any of this relevant? Maybe maybe not but, i'm bored and figured i'd type something up.
Old Feb 17, 2006 | 07:10 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
i have the 305 in my car now and havnt had much luck finding a 350 block so i just want to know if it was possible to make a 350/355/ect out of a 305. i know that i would have to bore the engine out but to what.
Old Feb 17, 2006 | 09:11 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Originally posted by flaming-ford diameter of the cylinder bored being 3.740 on a 305 and 4.00 on a 350[/B]
4 inches.
Old Feb 17, 2006 | 09:39 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
wtf was the last post about lol i typed 4 in i know what it is......
You can't just bore an engine to any magical # man.... if you bored out your engine 1/4 in on each bore you wouldn't have cylindrical cylinders at all and you'd have plenty kool combustion chambers (coolant passages would be your cylinder walls).
Max you can bore is .060 (60 thousandths) which would equate to a 310 cubic in motor when it's all said and done.
If you plan to do any block work like an overbore or align boreing then go to a junkyard and pull a 350 or 400 sbc from a vehicle and start there. A 305 just isn't worth the money if you need to do much machine work.
Btw no offense but, go to this site *howstuffworks.com
look at the internal combustion engine along with anything else car related you can think (forced induction has a good article). I love the site used to use it all the time a couple years back before i knew anything about cars. I still reference it ocassionally.
Basically find out more about what you're asking before you ask it, no offense intended we all have to start learning somewhere....
Btw go to the library after reading up at howstuffworks.com and rent some sbc buildup books (david vizzard is a very good author). That will tell you most anything you would ever need/want to know about engine building.
Btw a 355 is a sbc 350 with a .030 overbore (adds 5 cubes). a 360 is a .060 overbored 350 sbc. Or a stock dodge 5.9 liter engine if you wanna be technical but, i won't go there.
Old Feb 18, 2006 | 01:13 AM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
thanks
Old Feb 18, 2006 | 08:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Wow - never thought I'd ever see anyone say a 350 block was hard to find - I thought 350's were everywhere! There's no boneyards anywhere close? 350's were in trucks, vans, and most all larger cars from the 1950's until tomorrow and beyond.
There's plenty around here from free to whatever cash you have - not that does you any good - unless you like looooong road trips. You can even spend the night here, but be warned, I have 5 children in the house!
Old Feb 19, 2006 | 12:18 AM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
i go to the junk yards and every car that i look in has had the engine torn out. and when i do find them the people usually want way to much money for them.
Old Feb 19, 2006 | 11:04 AM
ljnowell's Avatar
Here is a little trick for you, go to the junkyard and tell them you are looking for a core for your pickup truck. Dont mention anything about performance at all. YOu have a cracked block and need to transfer your guts to it. There are lots of people when they think that it has performance in mind will double the price. Same with the vortec heads. Go and ask for some truck heads from that year, not vortec heads. Just asking to be gouged,
Old Feb 20, 2006 | 12:43 AM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
A little off the topic of this exact thread...But you said 350's are all over...Does that mean a 350 engine from a blazer is the same 350 engine in the camaro of the same year?
Old Feb 20, 2006 | 12:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
More or less. The block is the same.
Old Feb 20, 2006 | 01:17 AM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
if they are the same then why can you get a 2 bolt main or a 4 bolt main?
Old Feb 20, 2006 | 01:19 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At the factory they take the same raw casting and machine it to take 2 bolt or 4 bolt main caps. It makes no difference to any of the other parts, or to its suitability for street use which caps it has.
Old Feb 22, 2006 | 12:57 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
same deal here. i went to the local jy, and most of the crap they have, are tpi 305's they had one 350 with a tbi, he had no idea how many miles were on it, and he said they wanted 800 bucks for it. what a rip off. makes me just want to build my 305.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
