350 out of truck
Old Feb 18, 2006 | 10:22 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 5 speed
350 out of truck
allright i can get a 350 out a my brothers truck for free and replace my 305 wiht it and i was just wondering if its all gonna be worth it or would there be a alot of work for me to really get it running. i guess what im trying to say is there any differnce from a truck engine to a cars (sorry if sound stupid) so im just kinda new to all this but so try not to get to hard on me
Old Feb 19, 2006 | 12:40 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
overall exterior dimentions are the same....
Old Feb 19, 2006 | 09:02 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Most likely there will be an improvement unless the 350 is worn out. What year 350 is this? Depending on year you may need a new flexplate and do some minor modifications to get the intake manifold to bolt on.
Old Feb 19, 2006 | 09:09 AM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
its out of a 1991 chevey
Old Feb 19, 2006 | 08:08 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Re: 350 out of truck
Fbody891,
What's wrong with your 305? If you're 305 is running good, and not causing you any mechanical problems, swapping in the truck 350 to get some perceived performance gain is probably not going to net a gain equal to the amount of effort you have to put into the project.
In other words... IMPO - If the 305 is running good and you just want to transplant a stock 350 truck engine to gain some cubic inches [IMPO] don't waste your time.
On the other hand... if the 305 is near failure and getting ready to meet it's maker at the JunkYard in the sky..... You're bother's truck engine would be the perfect price and the perfect building block to BUILD UPON to replace a tired or faulty 305. Most guys around here wouldn't spend the time rebuilding a 305 when a 350 would be the same $$.
Sincerely,
Kurt
Old Feb 19, 2006 | 08:22 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
i see what our saying, but yes it is starting to show signs of wear, but with this 350 im not gonna gonna do this right away im gonna wait till the 305 is on the verge of dieing adn throw it in there. but i was also wondering heads could use for it that i can find in the junk yard that i can restore. i can do all of this at school
also do i need to move this to a section?
junkcltr
Aug 2, 2019 11:12 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
DJanes97
Sep 1, 2015 02:55 PM
Eric-86sc
Aug 24, 2015 09:01 PM
