Absolutely necessary?
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Is it necessary to install sub frame connectors right away with the v-8 swap into a 6-cyl frame. The problem is my camaro is a 6 cyl frame, with a mild 350(under 300hp). I've heard horror stories of people completely twisting the frame up to where they coudn't even put the t-tops in or cracking th e windshield down the center. Well the problem is the windshield is already cracked down the center from the Previous owner and don't want to escelate the situation by running it without SFC's for a little while.
V6-V8 is the same. The same bodies made both. If you did the swap, then you should know this. You are in no more danger than a V8 car with the same engine. However, if it has 300hp or more, yeah get the SFC's.
Transmission: 4L80E/4L80E
For what it's worth, the roof of my car was cracked at the upper door/window opening when I got it, while it still had the V6 in it.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Black,
Since you're relativelly new to TGO, know that searches here will provide a wealth of info.
JamesC
JamesC
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
Originally posted by JamesC
Black,
JamesC
Black,
JamesC
Not wrong. I simply thought you'd find info much more quickly than if you waited on replies.
JamesC
JamesC
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Originally posted by BlackRabbitZ28
Sorry to thread jack a bit but are SFC's a very difficult install? I come from the import scene and FWD's where torque is no issue =P
I have Competition Engineering connectors,and they involve cutting a channel out of the floorpan and welding in fom top and bottom.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Originally posted by Irockz
Stick with the bolt ons,and they aren't too bad.But some of the weld ons,while much stronger,are a more involved project.
This is one mod that when done correctly you can't go wrong with!!!
Engine: 305TPI
Thanks, i'll give this guy his thread back now. =P
There's nothing I've run into that I just can't do. I usually figure it out or ask someone and they tell me. I just run into things like not being able to weld. Other then that no one works on my car but me. A mechanic taking his car to a mechanic just doesn't seem right. I've just never installed SFC's we seem to not do many of those with the vehicles I work on.
Originally posted by Lo-tec
If you're gonna waste your time to do it, do it once. Bolt-ons may not be too bad, but they're not too good either. Buy a good set of weld in ones (good ones don't require channeling the floorpan) that are perimeter welded. If you don't know how to install them pay someone to do it.
Pac J
May 17, 2020 10:44 AM
WhteRbt
Sep 21, 2015 09:48 AM
