Engine ready to come out... Where to hoist engine?
Old Mar 13, 2006 | 09:19 PM
JB22's Avatar
OK, everything is disconnected now and the engine is ready to come out. Whats the best place to attach my cherry picker to to pull this sucker out?
Its pretty much still complete minus the a/c compressor is off to the side to save from having to decharge the system.
any input appreciated.
Old Mar 14, 2006 | 05:02 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Does the engine have the tabs bolted at the rear and front of the block? They look like metal eyelets. Or, you can use a length of chain and bolt to the rear and front of the block (the heads) and hook up to this. Make sure the bolts are tight enough.
Old Mar 14, 2006 | 05:49 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
yep I usually take a big chain and bolt it to opposite sides of the engine to the heads.
Old Mar 21, 2006 | 11:37 AM
jonarotz's Avatar
Car: 91 Z28
I yanked my engine and trans together. I bought a load leveler thingy from Harbor Freight tools for like $30. It made this job so simple. I would suggest getting one, you won't regret it.
Old Mar 22, 2006 | 09:46 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Load leveler maks it go in/out much easier. No dented fenter tops or header panel problems. Was worth the money (only 19.99 on sale!). Did the trans and motor in or out in under an hour each time by myself.
Attached Thumbnails Engine ready to come out... Where to hoist engine?-goingin.jpg
Old Mar 22, 2006 | 11:20 AM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
Load levers are great especially if you’re pulling the engine and transmission as one. Use at least two if not four of the accessory bolt holes on the heads (i.e. A.C. compressor and alternator brackets on the front w/ similar holes on the back) to lift the engine. Oh yes, make sure to use top grade bolts and washers snugged to the chain. It gets pretty frightening when the bolts start to bend and you have 700 lbs. above the nose of your car.
Jim
Old Mar 22, 2006 | 05:45 PM
JB22's Avatar
thanks for all the input guys
Old Mar 25, 2006 | 04:20 PM
JB22's Avatar
picked up a 2ton loadleveler today at harbor frieght for $15 on sale.
what kind of bolts do I need to get to screw into the heads? size/grade ?
Old Mar 25, 2006 | 04:23 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
I just used the accesory bolts from the front of the engine to attach the chains to my heads. work just fine for me. Just thread them in as much as possible
Old Mar 31, 2006 | 11:10 PM
net_coma's Avatar
Take the runners off so you dont bend/dent them.
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
backtothe80s
Sep 5, 2015 12:39 AM
The_Phoenix
Sep 3, 2015 10:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
