tricks to pull 89 tpi 350
Old Mar 20, 2006 | 05:36 PM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
Transmission: 700 R4
Axle/Gears: 3.23 I think?
I can't find the search, so any time saving tips? where to start? what to leave alone?
Old Mar 21, 2006 | 08:33 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I didn't even pull my intake when I did my 90. I had all the accessory stuff off before, so I might not be the best to ask about everything that had to come out. I did take off serpentine brackets (which included on mine pulling the pully for the power steering to unbolt it), disconneted all the wiring to motor, pulled headers, wiper motor, pulled the radiator (mine was to paint, but could be good safety precaution too), and other stuff to keep from crushing.
I put a floor jack under the pan of the trans to keep it from sagging. Friend did the regular stuff (disconnecting wires, unbolting long center bolt on motor mounts, hooking up chains to crane).
I used a turning tool to turn the flexplate to unbolt the converter (3 bolts). After that was done we finish'd taking out bellhousing bolts. Then jacked up the crane a little bit and got some screw drivers to help wedge gentlely into the bellhousing mount to seperate them. After that came apart we jacked up the crane some more and slowly pulled it out of the car. Really handy to have 2nd person there to keep it from swinging and to watch to clearance issues.
For tools: ratchet/socket sets, open and closed end wrenches, hoist, sling chains, flywheel/flexplate turning tool, screw drivers, GM pulley puller, floor jack, flash light
Old Mar 21, 2006 | 08:46 AM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
how long did it take start to finish? say I had everything ready to go...could I pull it and put heads and intake back on new block and install it in a day or two?
Old Mar 21, 2006 | 08:55 AM
Engine: 383 SBC
Easily, with 2 of use we disconnected wires, removed wiper motor, mounts, bell and converter bolts, and pulled the motor out and had it on a stand in about 2 hours. I'm just waiting on my por-15 to come to paint stuff before I bolt down the new solid motor mounts and put the new motor back in.
Old Mar 21, 2006 | 08:58 AM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
thanks...would any centerbolt short block work? my buddy has one out of a boxy caprice.
Old Mar 21, 2006 | 09:18 AM
Engine: 383 SBC
centerbolt? The centerbolts are on the heads....
Old Mar 21, 2006 | 09:19 AM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
ya...I know...but will a centerbolt short block out of a caprice work to get me back on the road?
Old Mar 21, 2006 | 09:21 AM
Engine: 383 SBC
I assume so... make sure it has the right size flexplate on it. Double check all your sensors and stuff are transfer'd over. I can't remember if theres any in the block or not but I think there is on the passenger middle side.
Old Mar 21, 2006 | 05:42 PM
bobman's Avatar
tpi
I'm currently doing a motor swap replacing the old 350 with a new 350 with atleast 350 hp I bought a set of headers but i dont have any connections for the smog pump tubes.Do you know if the car will run ok without using the smog pump I'm keeping the o2 sensors.Any feed back would be great.
Old Mar 22, 2006 | 09:31 AM
Engine: 383 SBC
Check out the exhaust forum, but in short yes. I capped mine once I gutted the CATs. Won't be emission legal though.
Old Mar 26, 2006 | 11:33 AM
Brent C.'s Avatar
Car: 89 GTA.
Engine: 357
One more question.....what are the valve sizes on the 350 TPI...are they a bigger valve than on the 305 tbi?...I ask because I have a set ot the 305 heads...I know they are a smaller chamber...but are the valves the same size? will they flow as good as the stockers?
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
