305 TPI to 350 TPI ??
Old Apr 9, 2006 | 11:33 PM
IRAWK
Guest
Posts: n/a
My 85' IROC has a 305 TPI. I am looking into Crate 350's, and was wondering if it was at all possible to use my current intake (TPI Setup) on a crate 350 (instead of having to purchase a carb seperatly, use the stock TPI intake)...
Just an idea, wasnt sure if it was possible.
Old Apr 9, 2006 | 11:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yes you can bolt it right on. But you may need larger injectors and definately some tuning to get it running 100%
Old Apr 9, 2006 | 11:47 PM
IRAWK
Guest
Posts: n/a
Oh yeah? thats awesome!! I'd much rather have TPI than carb
very much!
Old Apr 10, 2006 | 01:35 AM
iroc22's Avatar
You'll need the 350 knock sensor and ESC, also I would recommend 24lb injectors to feed the 350. You could just bump up the fuel pressure and try and compensate for the smaller injectors...
Old Apr 10, 2006 | 12:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Whether the TPI will be happy on the 350 crate depends entirely upon what 350 crate you're talking about. Goodwrench 350, no problem. 330 HP 350 HO, big problem.
Old Apr 10, 2006 | 01:25 PM
IRAWK
Guest
Posts: n/a
I haven't decided what one I want to do yet. I dont know alot about crates, but Im pretty sure they make one for fuel injection specifically... .. not 100% sure. I'm not looking to spend over $3500, and I understand its gonna take more than just dropping the engine in. Just dont know weather or not to throw a carbed one on, and loose the TPI system (which I would prefer to keep... & I also plan on supercharging it sometime downt the road)
& thanks for the help! I appreciate it!
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
