350 TPI headers after engine in or before?
Old May 14, 2006 | 02:39 PM
Ltrain925's Avatar
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i have an 89 vette tpi that i changed to carbed and i have shorty headman headers. is it easier to put the headers on after the engine is in and everything is hooked up or put them on before the engine is dropped in?
Old May 14, 2006 | 03:04 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
It's probably easier to put them on after the engine is in the car. That way you don't have to worry about messin up your headers/ engine bay.
Old May 14, 2006 | 07:07 PM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
Put the headers on after the motor is in. I tried to put my motor in with the Heddmans on and they wouldn't fit between the frame rails. They slipped right in after the motor was in though. Word of advice to save you time, don't put the motor mount bolts in before you put the headers on because you will have to take them back out to lift up the motor to slip the headers in.
Old May 14, 2006 | 07:47 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
Have a couple friends hold the headders in place in the engine bay as you lower the engine in. It was the easiest headder install I ever did (1 3/4 SLP's)
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
