ok need swap help... 400/t5
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
ok got a 87 t5 car... 153 tooth 10 inch clutch flywheel.
putting in a 74-80 400 sb. I need a manual flywheel that will fit my clutch and trans but work on that engine.
really dotn want to buy a centerforce, so id like to find something that wouldnt break the bank since the t5 will break then maybe by then ill have a t56...
any help where to get one
thanks
if this is in the wrong spot please move it
thanks
Car: 83Z28 HO
Transmission: G Force 5 speed
thanks
thanks
-Transmissions and Drivetrain??
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Originally Posted by Confuzed1
Sooo...the only critical info missing here is whether it is a stock externally balanced 400, or has it been internally balanced? And good choice - you'll never be able to break a T-56 with a 400, what - with that extra gear and all.
it is externally balanced.
what about this 400 balance plate im seeing in places? allows the use of a 350 flywheel (which is readily available in my clutch size) on a externally balanced 400
would this work?
Car: 83Z28 HO
I've never seen one, but I hear they have them. If so, that would be the cheapest option. Then you'd be able to use everything off your old setup.
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
so you are saying the balancer plate would be the easiest/cheapest route to go?
anyone heard of these, pros/cons maybe? if its just bolt on, and bolt your 350 flywheel to it, then it cant be that bad
also, what flywheel are you running or is yours internally balanced?
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I have used them with 400's and 454's,never had a bit of trouble.Should be your simplest and most affordable option.
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
just use regular flywheel bolts,and they have the dowel hole.You'd have to attempt to put it on wrong.
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
sweet guess i know what im buying now
thanks!
Hello, Michael
Aug 20, 2015 03:19 PM
