Old Jun 9, 2006 | 09:37 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
I pulled the stock 305 out of my 87 camaro and went and bought a 327 to replace it. I don't want to keep much of the "extra" wiring/junk under the hood after the swap. Is there any of that that really Needs to be hooked back up?
Also, looking to put an MSD ignition in. Any thoughts or opinions on models?
Old Jun 10, 2006 | 01:31 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did the 305 have a carb? If so, it will run your 327 quite nicely (assuming a reasonable cam), but it will need some of that wiring.
It really depends upon what you do for induction as to what you can remove of the wiring. Whatever you do, don't go slashing and cutting things, as what you won't need if you go with an old-school carb and distributor can be removed as a complete harness - just in case you find out you need it later, or someone on the Board could use what you no longer need.
Old Jun 10, 2006 | 10:54 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I did this swap. Be sure and lable the wires as you take them off the 305. If you are going with a carbed 327..all yo will need is about 5-6 wires to get her running. Tie the rest together and pu them by the passenger side fire wall. nerver know you might change your mind down the road.
Old Jun 10, 2006 | 04:51 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
I was plannin on goin with a holley 650 carb. i have no idea what cam is in the 327. All i know is its bored .060 w/domed pistons and has the old school 2.02 double hump heads. i know absolutely nothing about cams... i actually don't know much about alot actually... lol
Old Jun 11, 2006 | 10:49 AM
Engine: 406
do the heads have the acc. holes in the front? if not your in for some fabrication.
Old Jun 11, 2006 | 10:50 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
theres 3 holes on one side but i need to drill and tap one for the other side.
Old Jun 11, 2006 | 10:55 AM
Engine: 406
if the three are on the drivers side youa re in pretty good shape for mounting your power steering. you can get away without the passenger side hole by using aftermarket brackets for the alt. I did.
Old Jun 11, 2006 | 12:30 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
where does the bracket bolt to then?
I'm pretty sure the three are on the drivers side.
Old Jun 12, 2006 | 06:54 AM
Engine: 406
the bracket I use bolted to the waterpump and the intake mnifold.It held fine for the year I drove it on the street befor I swapped in the 406.Here is the typ Of btacket I used . I used it on the 406 as well.
Old Jun 12, 2006 | 03:15 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
how much did that bracket run you?
and what 5-6 wires are needed?
Old Jun 13, 2006 | 07:34 AM
Engine: 406
Ibelieve it cost around $20. The hardest wires to find are in the loom coming from the drivers side...there is a Fat pink wire along with a smaller tan brown wire these go to your distibutor (Positive and tach). You need the alterator wire, the starter wires, I had to lenghthen them some. Dont forget the ground strap at the back of the motor from the firewall. If you are coming from fuel injected you will need a fuel pressure regulator, Like the malory you see in the picture.Chances are your fuel pump wont run beyond prime....some do .some dont. If it doesnt you will have to rewire it up.
Old Jun 28, 2006 | 01:24 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
"Ibelieve it cost around $20. The hardest wires to find are in the loom coming from the drivers side...there is a Fat pink wire along with a smaller tan brown wire these go to your distibutor (Positive and tach). "
With changing carbs, don't you need to get a new distributor?
Anyways, I'm looking for a new distributor, carb, and ignition. All that fun stuff
What would be the best stuff to go with? The car is just for every day street use and I'm a small budget. The car's already been in pieces 2 months longer than expected! really itchin to drive it again.
Old Jul 2, 2006 | 09:45 AM
Engine: 406
yes you will need a V-8 distibutor. Cheap... Go to thr J/Y And pull a V/8 Dist. Bg Block Small block They are both the same...expensive..MSD Good Stuff. I ran a 600 edelbrock on my 327..easy to tune and a bit cheapre than the Holly. Get a good set of wires..MSD and go fron there.The EDelbbrock performer rpm intake is very popular.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
