LT1 with HEI
Old Jul 28, 2006 | 08:23 PM
RED396's Avatar
Car: 1989 IROC-Z
Engine: Was a 396 SBC, Now a 5.3l w/LS9 Cam
LT1 with HEI
Other than the obvious things, are there any major issues with doing this swap.
1. I know the intake needs fabricated for a distributor.
2. I will be keeping my 700r so I will need a 93 TB for tv hookup.
3. I will leave the opti on the timing cover.
4. My headers and exhaust will bolt right up.
5. I will have to re-wire the TPS.
6. I will not be running AC, so no K-member notching.
7. My existing motor mounts will bolt right up.
8. I will put an LT1 radiator in it.
9. The only issue I can think of is how to time the motor, but I believe that ATI's dampner has timing marks on it.
If anyone can think of anything major that I missed please chime in.
Old Jul 28, 2006 | 09:05 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
One thing....
Why???
Keep the motor the way it's supposed to be. Use the opti and let the computer do the timing, it will run way better if you do that.
And don't say it's to keep the old computer in the car, the newer PCM's are way more efficient and you will get more power by keeping the entire LT1 setup.
Old Jul 28, 2006 | 10:11 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
This could be done fairly easily. GM makes a plug for the front cover with a timing mark. It is for the carbed applications. Your sig states you have an IROC, is it TPI? If it is you could reuse a TPI throttle body and not have to rewire anything. The LT1 radiator is unnecessary. I am using a thirdgen radiator and have been for three years. You can reuse your TPI wiring. You will have to use a small cap distibutor with an external coil. I don't see why it won't work. You are going to get a whole lot of static about this, but I think it would be interesing.I found the part that takes the place of the Opti here is a part number and the web address.12367600 - LT1/LT4 Front Cover / Plug - Used When Optispark Is Eliminated On A Carburated Conversion - 12367600
Old Jul 29, 2006 | 01:29 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i would be interested to hear more about it actually.
Old Aug 5, 2006 | 10:26 PM
Firebat's Avatar
if you're scared of the optispark horror stories, they make coilpack conversion kits.
The LT1 pcm(computer) is so easy to work with too and program.
Old Aug 6, 2006 | 03:01 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Originally Posted by Klortho
One thing....
Why???
completely agreed. and if you are worried about the opti, MSD makes a completely brand new setup from the ground up. not stock replacement internals, brand new inside.
Old Jun 10, 2007 | 08:49 AM
polishdevil's Avatar
Car: 88 GTA
Re: LT1 with HEI
Did you ever do this? I plan on doing the same thing to not have to worry about wiring.
Old Jun 10, 2007 | 10:18 AM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Re: LT1 with HEI
I think cost-control is the reason for reusing the TPI running gear. In the end, I'm not sure how much it will actually save. Money- maybe, time- no. Time is money, right?
Aside from efficiency (which is open for debate when comparing 92-93 MAP LT1s to 90-92 TPI), the TPI's PROM will need reprogramming to compensate for the way the LT1 gets its power (cam, heads, timing, etc). I don't think it will be as easy as simply swapping in the right parts.
What would be great is if someone has already done the programming for a TPI to LT1 swap using the TPI electronics.
If you ever get the programming right- you'd do well selling those chips.
Old Jun 10, 2007 | 01:35 PM
Car: 88 GTA
Re: LT1 with HEI
I have the time and would like to do this swap as cheap as possible considering how much I spent on the 396 that went in the Vette; where the LT1 is coming from.
I figured I would need the intake machined for the distributor, a distributor and then have Alvin from PCMFORLESS burn me a chip for it. He tuned the LT1 when it was in my Vette and it ran damn well. Any issues using the 88 ECM to control the LT1 that way?
Old Jun 10, 2007 | 02:20 PM
Klortho's Avatar
Car: 1987 GTA
Re: LT1 with HEI
You have the engine harness and the PCM from the vette, no reason to do that, just put that in the car. If you are using the PCM and engine harness, you can get an f-body harness and PCM for a fair price.
Old Jun 10, 2007 | 09:57 PM
Car: 88 GTA
Re: LT1 with HEI
The harness and ECM were retained on the Vette. I do have a spare Vette harness but finding an ECM is hard.
I think the wiring aspect would be more time consuming and costly than having the intake modified and running a distributor. Am I missing something here? I just want it to be as easy as possible and relatively cheap.
Old Jun 11, 2007 | 05:36 AM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: LT1 with HEI
I had to connect 7 wires to get my LT1 done. I would keep it a full LT1... Just my opinion...
Old Jun 11, 2007 | 06:18 AM
Car: 88 GTA
Re: LT1 with HEI
Please do explain
Old Jun 11, 2007 | 01:14 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: LT1 with HEI
It's all in the LT1 for dummies thread. You have your 12+ battery, 12+ switched, ground, fuel pump, cooling fans, Neutral switch, TCC power, and your gauge senders.. that's about it. You only need 4 wires for it to run, the 12 volts, ground, and your fuel pump.
It's a lot less work then swapping your entire TPI setup over, not to mention that most people are swapping their TPI intakes to LT1 intakes for more power.
In either case, good luck with whatever you do!
Old Jun 11, 2007 | 02:17 PM
Klortho's Avatar
Car: 1987 GTA
Re: LT1 with HEI
There are like 4 PCM's on ebay right now, they're easy to find, doesn't have to be specifically a vette, can be an f-body, vette, roadmaster, impala, caprice. Basically anything with an LT1, I would suggest using either a '94 or '95 PCM though.
88SS6SPEED
Nov 11, 2015 07:05 AM
skinny z
Oct 5, 2015 06:23 PM
WejaZ28
Oct 3, 2015 07:38 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
