universal 350 crate swap ??s
Old Oct 25, 2006 | 10:25 PM
transam84's Avatar
I am thinking about putting a GM Universal 350 crate motor in my 86 T/A and pitching the 305 carbed motor. this crate motor is only $1,300, and for the price it is not a bad upgrade. my questions are this:
#1 do I use the 305's Harmonic balancer on the 350??
#2 can I use the same flex plate thats on the 305 on the 350??
#3 can I use the 305's starter on the 350?? not sure if the 350 has a stagered bolt pattern for the starter.
#4 can I use the 305's distributor and hook that along with everything else up to the 305's computer?? if so do I need the computer to be modified for the 350??
for the time being I would prob just use the 305's intake and carb until I would get some more money saved up for a performer intake and better carb.
if there is something I am missing here please chime in. this car is for a daily driver in the summer, I already have a 383 stroker T/A so I do not need another high hp car, just a good dependable cruiser.
Old Oct 25, 2006 | 11:18 PM
83Chevy__Camaro's Avatar
most small blocks are created equal, the distributors going to work, the computer is set up for a 305 though so i dont know if thats going to work, the intake works as well, almost all the outside items will work, for the starter, im going to guess since it lists a high torque starter for sbc that they should all work, but they sell different starters for different clearance issues under the car.
Old Oct 26, 2006 | 12:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's the 260 horse version. Have you considered the 290 horse version?
Yes, but the timing marks won't line up. I'd just get a new one, no more than they cost.
No, the '86 engine has a one-piece rear main seal, and the Goodwrench engine has a 2-piece. You need a $25 153-tooth flexplate.
Yes, with the above-mentioned 153-tooth flexplate.
It will run it just fine without modification. I'd suggest a better coil and ignition module, and fresh plugs, wires, cap, and rotor.
The intake will be fine. There isn't a better carb. The carb secondary AV, rods & hanger are good things to tune up, even on a stock LG4.
The stock exhaust and air cleaner are really lame, and are going to hold back the performance even in regular street driving. Consider upgrades there while you're at it.
You should also get a 350 knock sensor and module.
You're basically considering a tame version of what I've done.
Old Oct 26, 2006 | 04:02 PM
transam84's Avatar
five7kid, I just looked at the 290 version. that might work pretty good !! thanks for the heads up on that one. you wouldn't know a ballpark $figure on a Knock sensor and module would you, I assume any dealership would have these right??? I am just trying to figure out total costs here.
Old Oct 26, 2006 | 04:59 PM
five7kid's Avatar
I got mine from gmpartsdirect.com . I believe they were a little over $100 for the two. Dealers were about 30-50% higher.
Old Oct 26, 2006 | 08:01 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That GM Goodwrench cheapie crate engine is not for performance cars. It has crappy heads, a crappy cam, and crappy compression. Its 350 cubic inches with the power of a 305. Remember, that's 250 HP GROSS, not net. That means without accessories, without exhaust, etc. Once you put those on it, its probably more like 200 HP or less.
Old Oct 26, 2006 | 09:53 PM
User Name:'s Avatar
Send me a link to that 350?
Old Oct 27, 2006 | 01:11 AM
five7kid's Avatar
Don't forget the originator's goals:
That's what makes the Goodwrench engine an acceptable choice. With exhaust and air cleaner upgrades, it will be just fine for the intended purpose. You could argue that a 305 with the same upgrades would be as well, but the 290 HP Goodwrench in particular will make more power than a 305 with the same upgrades, and certainly have more potential with future upgrades (such as porting the 305 heads, installing 1.94" intake valves, and putting them on top of it).
Old Oct 27, 2006 | 11:40 AM
Polecat's Avatar
GM Performance Parts 350 C.I.D. 290 HP Engine Assemblies: NAL-12499529 - summitracing.com
290 HP
Old Oct 27, 2006 | 11:03 PM
86/01's Avatar
can you use tpi system with these motors?
Old Oct 30, 2006 | 02:01 PM
five7kid's Avatar
It's been done.
Old Nov 16, 2006 | 08:08 AM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
if anybody is interested, jegs sells the motor for a hundred less...
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
theshackle
Aug 22, 2015 06:52 PM
