HSR 383 Engine install? Can I? should I?
Old Feb 14, 2007 | 03:52 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ok..I m wanting to install my engine this weekend....
I made a lift plate out of 1/4 inch steel and bolted it to my 4 plenum holes in my stealthram intake...I know they will hold the engine cause I have already tested it and lowered it in the bay ....but found out I need to grind on some things...
My question is do you think I can bolt my torque converter and transmission to the enigne and lower it down in the bay?
Do you think the plate and the bolt holes will hold without striping out or elongating the holes?
I dont want to ****up my intake....and have the motor DROP!!!
Old Feb 14, 2007 | 04:26 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Isn't the intake aluminum? No way would I feel comfortable doing that with my engine - especially with a transmission hanging off. Why not use the accessory bolts on the heads like most other people.
Old Feb 14, 2007 | 04:33 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Heli-coil them first and I would say yes.
If not then acessory holes in the block.
The heads are aluminum too. So why go from aluminum to aluminum?
Old Feb 14, 2007 | 04:47 PM
Car: 86 T/A
Engine: HSR 355
Vertical (intake) VS Horizontal (heads)
I'm not saying the intake won't hold, I really have no idea, I'm just saying it makes me nervous.
Old Feb 14, 2007 | 06:18 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
In order for you to break a helicoil, you would need to pull 12 bolts from the lower manifold from sheer force. You put four helicoils in and you will never strip it or cross thread it. The tighter you make the bolt the more the helicoil cuts into the aluminum.
Old Feb 14, 2007 | 09:16 PM
i dont have a problem using it the way it shows....it will hold fine..I was just wanting to drop in the motor and trans together...but I guess I'll just do the motor by itself...and put the trans in from under the car...its just a pain doing that...but I would much rather do that than break the bolt holes on the intake.
ive seen plenty of lift plates attached to aluminum intakes where the carb goes...I just figured this was no different
Old Feb 14, 2007 | 09:41 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
EXACTLY!!!!!!!
Old Feb 15, 2007 | 11:47 AM
any specifc torque on the motor mount bolts? or just as tight I can get them?
thanks!
Old Feb 19, 2007 | 07:24 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
I'm sure you could find a torque spec for every bolt on the car, but just get them tight. You don't have to go crazy with it just tight. Motor looks really nice!
Old Feb 19, 2007 | 07:34 PM
thanks!..yeah its been a pain to get this far and I hope its well worth it..Ive been working on it for a year...it would have been sooner but I had to wait 5 months on the freakin AFR heads...so I would have had it done a whole lot sooner...
Old Feb 20, 2007 | 09:23 AM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
Your plate should hold fine....i've had my engine in and out three times, tranny attached each time...i have an aluminim brodix intake, and i have never been worried about any thing breaking. I know it seems like it should, but i know several guys in my area who use liftplates bolted on where their carbs would be, no one has trashed an intake yet.
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
