almost ready to swap!?!?!?!
Old Apr 15, 2007 | 12:36 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
here is the situation i have an 87 firebird 305 th700 carburated that is just itching to get my 355 casting #14093638 and t5 in it. now from searching the forums and with the help from all of you good people here on TGO i have decided to go with the 081 heads off of the 305 and I'm gonna use the roller cam out of it too the issue is 1.) passing emissions in mass (i do know someone) i just need to know how to cheat the system 2.) all the little problems i will occur like the thing i just read about the motor mounts and removing the a arm and a couple of other things like how much lift can the 081 take stock and what is the combustion chamber on the 081
Old Apr 15, 2007 | 10:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only "cheating" is the 350 itself. Since it looks just like the 305, no particular problem there unless they get **** there like they do in California.
Keep the complete carb & control system. If you use the stock cam, no issues with lift (not sure what you're asking there).
It should pass without any problems.
Old Apr 16, 2007 | 10:37 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: almost ready to swap!?!?!?!
well i there is no cats on the car and all the emissions stuff is junk, crimped or both i was wondering about the cam thing because i wanna cam it and port the heads this winter how much of a difference will the 350 make with all the same components maybe i should just swap out the deep fried th700 for now
i went to the camaro heaven in NH today and got the clutch pedal assy along with the master/slave cylinder assy today so im ready to dig in
Old Apr 22, 2007 | 10:18 PM
mxcrazed's Avatar
Engine: None
Transmission: none
so i pulled the engine and tranny this week i installed the clutch setup and pulled the 081 heads off my carbed 305 then i pulled out the roller cam so that i can put it back in my 350 my question is do i need to use break in lube on this 305 cam when i put it in the 350 and will my push rods be long enough for this felpro head gasket also will the head gasket from autozone work with my .030 over bore?
thanks for any help you guys can offer!
Old Apr 22, 2007 | 11:53 PM
five7kid's Avatar
No cam lube necessary, that's just for flat tappets. Just make sure they're well oiled.
Forgot to ask if the 638 block was machined for the roller lifter provision. Some are, some aren't. If it isn't, you'll need to go to a flat tappet cam.
If it was roller lifter, then the pushrods from the 305 will work fine. The head gasket won't make enough difference to bother with. And, the head gasket is most likely a generic SBC gasket, good for anything up through over-bored 350.
By the way, the 081 castings are advertised as having 58cc chambers.
I would think you'll need at least a cat to pass sniffer. But, you may get lucky.
The 350 will make a significant difference if your exhaust and air cleaner are up to the task. Be nice to that poor T5.
Old Apr 23, 2007 | 09:27 PM
mxcrazed's Avatar
Engine: None
Transmission: none
thanks a ton five7 today i reassembled the engine with out any hangups thanks to you guys at tgo the only thing i didn't know was how much to torque the heads so i used red thread lock and 55 ft lbs is that good enough? two more questions for today there is a little butterfly in my stock passenger exhaust flange. what is it for and what is the best method for reinstalling exhaust manifolds + torque specs
thanks a lot
Old Apr 30, 2007 | 09:14 AM
mxcrazed's Avatar
Engine: None
Transmission: none
so finally i got her running i havn't had too much time to do anything asthetic but i got the 355 and t5 in there and drove her in my driveway but shes not registerd yet and still has a big hole in the floor but i was wondering about the knock sensor there are two plugs on my wiring harness one runs down withthe starter wires thhe other is longer and im not quite sure where it goes on the back of the right head? can i jump one out or ground it so that my timint will go back to normal and does it matter which one plugs into the passenger side one?
Old Apr 30, 2007 | 09:58 AM
irocman88's Avatar
Car: 88 IROC
Engine: carburated 350-- H/C
Transmission: TH350
Axle/Gears: 10 bolt w/ auburn posi and 3.73s
think head bolts are actually supposed to go to something like 75 ft lbs......
Old Apr 30, 2007 | 10:01 PM
mxcrazed's Avatar
Engine: None
Transmission: none
yea i looked up the spec and got two differnt ones 65 and 68 so i torqued them to 68 thanks!
Ikes 91Z
Dec 9, 2015 03:49 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
