305 TBI to 305 TPI
Old Apr 16, 2007 | 07:26 PM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
305 TBI to 305 TPI
I gave a search a whirl, found *some* info, but nothing as detailed as I'm looking for. I have an '88 TBI T/A and am wondering if I can use the block I have and convert it to a TPI setup without pulling the engine.
I'd like a list of parts that are needed, and if its worthwhile power wise considering the car will still be running with the swirl heads (unless it is necessary to change them too for a TPI conversion).
Thanks for your time!
Old Apr 16, 2007 | 07:43 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Re: 305 TBI to 305 TPI
Honestly, I don't know what TPI I does, and if it involves lots of parts and becomes expensive... you could build a 350. I heard its cheap.
Old Apr 16, 2007 | 11:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes its possible to change the intake, replace the computer, and repin the wiring harness while the engine is in the car. My dad did it on his old '92 RS. There is a tech article on this site that helps, but its old and outdated now. You can search for posts on this swap by myself and my father Dyno Don.
The car went from 158 RWHP to 176 RWHP, and 220 RWTQ to 290 RWTQ, using the same camshaft, heads, and exhaust manifolds as stock, but the cat-back was changed to a stock 2.75" from an 85 IROC while it was still TBI. Gas mileage also increased a little, like half a MPG.
Old Apr 17, 2007 | 09:44 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
Now THATS what I'm looking for!!!! Thanks, I'll be searching out your family's thread. Any idea where you posted it?
Old Apr 17, 2007 | 09:47 AM
Ogre91's Avatar
Car: 91 Camaro
Engine: LO3
Transmission: T5 (converted from auto)
Axle/Gears: stock RS
t/adreams, I am looking for this answer too. I will share what I find.
Old Apr 17, 2007 | 10:12 AM
blizzted's Avatar
Car: 2000 tahoe,94 ex-cab,92 rs
Engine: 350,350,305
Transmission: all autos
when you guys find please let me know as well.I am doing the same thing but im replacing the 305 with a 350 in my car,I was going to stick with the tbi but after the price of boring out the tbi,getting new injectors and other nickel and dime stuff i just went to ebay and got a complete used tpi with a puter for 200 bucks,Now heres what i wanna know can the tbi harness still be used but modified,also what sensors if any will interchange such as map,ecm and also the dist.,and the fuel pump will have to swaped out im sure....
Old Apr 17, 2007 | 02:13 PM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
im alos looking to go from a 305 tbi to a 305 tpi. my donor car is a 1988 t/a tpi can i use the 1988 stuff on my 91 camaro?
Old Apr 17, 2007 | 02:52 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Hmm, I haven't done this, but I do know that the TBI fuel pump is way too weak (around 14 psi) to fuel TPI (needs around 36 psi). So on top of the TPI swap, you'll need to upgrade your fuel pump.
Old Apr 17, 2007 | 10:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pressure is a function of the restriction produced by the regulator. A TBI pump may produce 35-45 PSI, but it won't be able to keep up with the required flow at that pressure. So, it is true that you need a different in-tank electric pump, but not for the reason stated.
The TBI can be changed out with a TPI, but the heads and cam of the TBI engines weren't as good as the TPI engines. The best way to do the swap is to change the complete engine (or at least the heads and cam along with the rest of the TPI stuff), harness, and computer.
You should be able to use earlier TPI equipment in a later chassis.
Kevin91Z already answered the question about using the TBI harness on TPI - yes, it can be done, but you have to "repin" it. Easier to just get a factory TPI harness.
Old Apr 18, 2007 | 09:04 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Thanks for clearing that up.
Old Apr 18, 2007 | 10:59 AM
blizzted's Avatar
Engine: 350,350,305
Heres a link to a web site i ran across today it has tons of great info on it
http://sethirdgen.org/tpi1.htm
Old Apr 18, 2007 | 01:36 PM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
great link
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92purpz28
Aug 11, 2015 02:30 PM
