L98 from a Corvette
Old Jun 25, 2007 | 06:22 PM
Alex IROC Z-28's Avatar
Car: Camaro IROC Z-28 1987
Transmission: Automatic
L98 from a Corvette
Hi guys I need some information....
I am buyng I L98 TPI form a Corvette and the guy said comes with a 700R4 too ...
Well my car is 305 TPI 1987 and the person said this is coming from a 1987 corvette as well....
How bad is tho put this thing there?
Any good advice before I buy this engine to check how good is it? Everycar motor and transmission has his catchs....so I am here to learn a bit....
Well I am the most familiar with that 4 cilinders swaps but I this car for 4 years and is time to upgrade it.
Thank's for the help
Old Jun 25, 2007 | 11:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The tailshaft housing of the Vette tranny won't have the torque arm mount provision needed, but the one from your Camaro will swap over to it.
Try to get the ECM as well. Not necessary, but better than using your 305 computer.
Old Jun 27, 2007 | 09:55 PM
Re: L98 from a Corvette
Thanks for the info...
I am getting everything including....ac pump, power stering, alternator, wiring and ECM....for the 87 you recomend change the chip? any good tip how to improve the engine before I put it on?
Old Jun 28, 2007 | 12:40 AM
Stephen's Avatar
Car: 87 GTA
IIRC, the accessory mounts are different in the Vettes too, which means, finding a pair of F-body brackets.
Old Jun 28, 2007 | 12:46 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
fuel rails are differant, egr and manifolds are differant too. you would bassically use the long block and injectors. swap all your old stuff back on top and get a tpi 350 chip
Old Jun 28, 2007 | 12:56 PM
Guest
Guest
Posts: n/a
You cant use the F-body manifold and EGR and expect it to work, there's no heat crossover in the heads. Thats why its plumbed into the exhaust like it is. You'll either need to eliminate it, or hook it up to your exhaust somehow. You will need to swap the fuel rails from your car, the entrance/exit for the Corvette is in a different location. Use your accessories as well. May as well keep your harness, just swap the chip from the Corvette.
The heads respond well to porting, if you feel like doing that. A mild cam swap wouldnt hurt either.
Old Jun 28, 2007 | 01:08 PM
Engine: ls1, LB9
it will work the egr just won't function
Old Jun 29, 2007 | 12:05 AM
Guest
Guest
Posts: n/a
Thats what I meant.
Old Jul 12, 2007 | 05:24 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
The oil pan will be different. as long as the vette motor doesn't have aluminum heads the egr will work fine. I think the egr gases were pulled from the exhaust when the vette got aluminum heads.
Old Jul 12, 2007 | 05:30 PM
five7kid's Avatar
If it's from an '87 Vette as claimed, it will have aluminum heads and the external EGR piping.
Old Jul 12, 2007 | 05:41 PM
Jproz1167's Avatar
Thought 87 was the year the convertible got the aluminum heads only. and the hard tops got them later.
Old Jul 12, 2007 | 05:43 PM
five7kid's Avatar
All I've ever heard is all '86-1/2 and on were aluminum heads. But, I certainly haven't heard it all, especially about Vettes.
Old Jul 21, 2007 | 02:20 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
The first generation of aluminum L98 heads started mid year 1986 from what I understand. All 87's had them. That is the older head though, the 113 casting wasnt untill 88 or 89.
FormulasOnly
Jul 23, 2018 08:47 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
italiano67
Sep 22, 2015 08:42 AM
