3.1v6 to v8 wiring
Car: 72 s.w.b. c/10
Engine: 350ci
Transmission: 350 turbo/shif kit
3.1v6 to v8 wiring
hey guys
i've read the post on this, my problem is the car i got had no motor and nothing was marked and it looks like one plug was cut off. this car had a 3.1 v6 1990 model i'm putting in a mid to late 70's 350 with a th350 trans i dont want anything under the hood i dont need, have all my own gauges,oil,water fule so on will i need to keep anything other than wires for alt,dis and run lights. any ideas on wire color or pics would be great.
thanks don
thanks don
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 3.1v6 to v8 wiring
Can you tell which wires are for the coil, lights, and alternator?
I might be able to help you decipher a few of those. Doing a project like yours, you really should have a wiring diagram. There are very good ones in the Chilton's total car care manual and decent ones in the Haynes manual as well. You need the firebird specific one if you are hunting headlight wires as well.
Let us know...
Let us know...
Car: 72 s.w.b. c/10
Engine: 350ci
hey krisw
i'll have to look into a manual the only one i have is for 82-92 camaro is it that hard to get rid of computer but keep lights. light wires are easy to follow,found starter wires i think, not sure about coil or dist there are four sets of wires that have been cut. don't know what this car had for a dis set up in cap coil or what.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by dnk5chevy
is it that hard to get rid of computer but keep lights. light wires are easy to follow...
found starter wires i think, not sure about coil or dist there are four sets of wires that have been cut....
Sounds like you already have your starter wiring already sorted out. All that's really left is your ignition wiring (and fuel pump, if you opt to run the stocker, which I would recommend). For simplicity, get yourself a distributor w/an internal coil. All of the other ECM wiring you can discard (since your running aftermarket gauges, which come with their own wiring)....
Engine: 2.8/TBI/TPI
You would have had a remote coil distributor. Everything in our cars had that after 86...
Your ignition coil will need the big fat PINK wire under the hood that comes on when the ignition switch is on. That wire will run your HEI cap-in-coil setup for the engine you put in. If you decide to run your electric pump with a fuel pressure regulator for your carburetor then you will need to put in an oil pressure switch on the engine to turn it on and keep it on with oil pressure. There is an orange wire (12v hot at all times) and a grey wire (powers the fuel pump) under the hood that goes to this plug. If you don't have this plug anymore (there is probably a third wire that goes to this plug for the oil pressure gauge in the dash) then you can tap these same color wires from the fuel pump relay to make it work.
Car: 72 s.w.b. c/10
Engine: 350ci
hey guys
lethal i did mean head and tail lights,i'm pretty sure i found starter wires, i was thinking of dumping the elec. fule pump you think it's better to keep it?
your right this will be carbed motor. i just want to clean up engin bay only want to see motor and the few wires needed to run heck i'm even dumping the ac and all it's componets. where is the power coming from to run all the lights if i remove computer and wiring the alt?
Originally Posted by KrisW
You would have had a remote coil distributor. Everything in our cars had that after 86....
Car: 72 s.w.b. c/10
Engine: 350ci
you got it going back to the basic in cap coil hei you say its a three wire hook up? the motor its in now only has two one to batt side and one for my tach. unless you mean the plug from cap to dist. internals its got three.
Engine: 2.8/TBI/TPI
One big fat pink wire for the HEI hookup, like I said before...
