454 can it be done.......
Old Sep 4, 2007 | 08:02 PM
woodstock16's Avatar
Car: 1985
Engine: lg4
Axle/Gears: ????????
Ok guys i have a question. I have found a 454 with a muncie 4 speed.the 454 has not run for 2 years but i have a friend that is a great with motors and drove the truck before the guy that has it now got and my friend says he can get it running no prob and the guy says if not then i dont have to pay him till it runs or i take it back to him.The muncie has a new pressure plate and clutch. The guy wants $500 and from what I,ve heard the tranny is worth that, but can I put it in my camaro and if so is it reasonable....my friend said he would help me with the swap and frame baceing.So...................your turn let me have it.
Old Sep 4, 2007 | 08:05 PM
noahTHEpurdy's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Re: 454 can it be done.......
Yes you can, it's been done quite a few times.
Old Sep 4, 2007 | 08:15 PM
Car: 1985
Engine: lg4
how much trouble will it be and i heard it is not exactly legal
Old Sep 4, 2007 | 11:33 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
well technically its not legal b/c a big block was never a factory option in a
3rd gen but o well im going to be doing a 454 soon myself. as of now i need to get it rebuilt. i am doing a automatic swap instead though instead of a manual. oh and has for how easy it will be, well it all bolts up fine, its a tight fit for the distributor, some have had to make dimples in the firewall because of it. also headers can require a grinder be taken to the k-member, a tubular k member would be great for this swap (thats what im doing). the distance between the radiator and water pump will also be tight but with a short style water pump the clearance can be slightly increased. If you use a short intake you may be able to use the stock hood although some short of hood scoop i.e. a cowl induction hood would make your intake choices grow, and also should help keep your underhood temp down. hope this helps some. their is also a sticky on top of this forum that may be of better use. good luck
Old Sep 5, 2007 | 08:38 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by woodstock16
how much trouble will it be and i heard it is not exactly legal...
Had one in my old '86 Iroc, absolutely no trouble at all. Check out some of the stickies in reference to swapping in a BB engine. As far as being street legal, your car is an '85, and although I'm floored at just how fast time flies (as I remember your car when it was new), it's now considered a classic. If your willing to drive her only a certain amount of miles per year, consider different insurance options, some of which would not only allow for you to run a big block, but to literally run open headers, on the street....
Old Sep 5, 2007 | 10:16 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
open headers depends mainly on where you live some states dont care but municipalities within do. like Las Cruces, NM. as far as the difficulty level just remember that space is limited in our cars but they do fit. A slow, steady, and smooth aproach is your best bet, if you get in a hurry because the itch to drive it is soooo great your likely to have problems. best of luck and have fun.
Old Nov 19, 2010 | 06:53 PM
chandan's Avatar
Car: 83 z28
Engine: 355
Transmission: 5 speed
i am looking at a 86 camaro with a 454 big block bored to a 468. i will aprreciate it if you could tell me what things to look for before i buy it? it has 67000 k on it
Old Nov 19, 2010 | 08:19 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Welcome to our forum. I don't think you'll get much response in this thread, it's 3 years old! Good luck!
MustangBeater20
Oct 29, 2022 09:20 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
