v6 frame with v8 engine
Old Nov 8, 2007 | 12:21 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
ive heard that the v6 frame is not as strong as the frame from the v8. Does anybody know if this is true or not?
Old Nov 8, 2007 | 12:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not.
V8's sometimes have little corner braces between the front crossmember and frame rail that the V6's don't have, and sway bars that are beefier.
But, other than that, the frames are identical. All of them, without exception, need subframe connectors.
Old Nov 8, 2007 | 10:58 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: v6 frame with v8 engine
yea, what five7kid said. although my 89 has the little corner braces and it was originally a 2.8, go figure.
Old Nov 9, 2007 | 07:10 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
my old 91 3.1 had cornor braces as well.
Old Nov 9, 2007 | 11:16 AM
five7kid's Avatar
They probably started putting them in everything, but my '82 V6 car did not. I only knew it existed because the '86 V8 donor car had them. The holes for the self-tapping bolts were even there on the '82.
But, the short answer is, the frames themselves are the same.
Might even be covered in the V6-V8 sticky (if it isn't, it will be ).
Old Nov 9, 2007 | 11:41 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
five7
my 82 TA doesn't have these braces either I tyhink it was more of a ws-6 thing at first.
Old Nov 11, 2007 | 12:07 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
thanks good to know. I guess now ill get under the car and make sure mine has the corner braces.
Old Nov 11, 2007 | 04:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mine "had" the corner braces but they were removed when I installed a tubular k-member. The BBC has no problems sitting in the frame. OK, I guess it's really sitting on the frame since I use a front motor plate that's bolted to the top of the frame rails.
Technically, third gens don't really have any sort of frame. The front frame rails are really multiple layers of sheet metal all spot welded to the main body of the car. Same for the rear frame rails. A third gen has no real front or rear frame rail structure like in a first or second gen. The entire body and framework are all just sheetmetal. Structurally, all the third gens have identical frameworks.
Old Nov 11, 2007 | 05:06 PM
Stevo's Avatar
Car: Pair of 92 Z28s
and suck.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
83RDRACR
Mar 26, 2016 08:13 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
meeklay812
Oct 1, 2015 03:46 PM
SG91camaro
Sep 5, 2015 10:27 PM
