L03 to LT1 swap
Old Nov 14, 2007 | 09:35 AM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
L03 to LT1 swap
I am about to buy a LT1 to replace my L03. I know I need the harness and ecu. Is there anything else I would need? I have heard of problems with ac. Is there any way around this? I just want to make sure I get all the parts I need the first time. Lastly are there any other problems I might face?
Wes
Old Nov 14, 2007 | 09:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you read the LT1 sticky in the top section of this forum?
Old Nov 14, 2007 | 03:53 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
Re: L03 to LT1 swap
i just did. It was very helpful, but I have some more questions that I'm sure all of you can answer. Im new to engine swapping.. I finally decided the L03 wasn't worth modding. The first qutestion is.. the LT1 I'm getting is from a Roadmaster. Is this version of the LT1 worth it, or should I look for a L98. This is the only LT1 I can find that I can afford. If it is worth it, what do I do about the Acc.?
Old Nov 14, 2007 | 03:59 PM
five7kid's Avatar
The AC compressor sits low and will hit the stock 3rd gen crossmember. The solutions people have used are: bang on the crossmember with a big hammer until the compressor clears; notch the crossmember by cutting out a chunk, flipping it over, and welding it back in ("boxing" the notch); an aftermarket tubular k-member that doesn't come close to the compressor.
Some people like the iron Roadmaster/Caprice LT1 heads better. The cam is less aggressive than f- or y-body LT1's, so the power isn't quite as high. Apparently they have the same power potential, you'll just pay a slight weight penalty for the iron heads.
Old Nov 16, 2007 | 01:30 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
Re: L03 to LT1 swap
a few more questions
first, Could you tell me why some people like the cast iron heads?
Second, don't shoot me, but I do plan on using my WC T5. Why do people say to use the 305 flywheel?
Lastly, In the guide do I follow the installment of the F-body Lt1 for my Roadmaster LT1?
Thanks again
Old Nov 16, 2007 | 03:30 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: L03 to LT1 swap
People say to use the 305 flywheel because thirdgens never came factory with a 350 and manual trans.
You can get the T5 setup to bolt up, however the VSS pulse issue comes into play, there are hackjob ways to get the correct signal using a T5, but I have yet to see one that I would use IMO....
Some people like the iron heads cause they flow more out of the box.
Old Nov 16, 2007 | 03:43 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: L03 to LT1 swap
is the roadmaster LT1 really an LT1 or is it and L99, the same 4.3l 265cid engine used in caprice's? Or is it the 5.7l LT1?
Old Nov 16, 2007 | 06:27 PM
five7kid's Avatar
It can be either one, so you need to watch what you're getting.
Old Nov 17, 2007 | 04:24 PM
89RsPower!'s Avatar
Re: L03 to LT1 swap
can you tell just by looking at em? I mean are there external differences you can see or do you have to go by casting number?
Old Nov 17, 2007 | 05:14 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: L03 to LT1 swap
Its cast right into the block by the casting numbers, the block will flat out read 4.3 or 5.7
Old Nov 18, 2007 | 04:00 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
Re: L03 to LT1 swap
Can't you tell its a LT1 by the VIN P?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
