Swapping From 305 to Older 350
Old Dec 8, 2007 | 02:55 AM
Drone358's Avatar
Sup guys, 92 rs Camaro and have a 80's Engine=500hp and im wanting to rip out all the wires and getting rid of the computer... not having AC anymore but jus confused on the whole wiring deal. If i need to keep the computer and get me a Painless Wiring Harness.. or Rip it out and hard wire everything or how im gonna use it for my distributor.. Please... Any ideas.. In process now
Old Dec 8, 2007 | 05:56 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Swapping From 305 to Older 350
If you're ripping everything out and dropping in a carb'd engine, all you need is the old HEI with vacuum advance. The only thing your computer can do for that setup is cry...
Also, with a 500HP engine, you're probably not too worried about the torque converter lockup for highway cruising and mpg. If you are, you can buy a kit to manually lock it up from most aftermarket guys like Jeg's or Summit.
Old Dec 9, 2007 | 05:44 PM
irocnz's Avatar
Car: 1986 Iroc Camaro
Engine: 406 small block
I have been down this road. got rid of the 305 tpi and computer and dropped in a 500plus horse 406. Encountered no problems and all I had to do was get an electrician to rewire the factory gauges.check it out Ran an 11.8 first time out. http://www.cardomain.com/ride/2927006
Old Dec 9, 2007 | 07:29 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
You could have removed your sending units from the 305 and put them on the 350 and they would have worked fine...
Old Dec 9, 2007 | 11:37 PM
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
this made my night
Old Dec 10, 2007 | 07:46 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Well...
Sometimes words can not adequately express my feelings; what can I say?
It made me laugh as well after reading it again!
Old Dec 11, 2007 | 11:18 AM
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
for the guys that done it. im goin to be swapping 70's engine into my 92tbi car. questions here are......will i need a new flywheel? its an auto car. but i keep hearing stuff about the flywheel. not sure if its just for the 5 speed cars or not. but it comes iwth the starter also. so if i change flywheels. what would i do about the starter? next question. about the carb setup. dont they sell a carb linkage for this swap? im kind of planning early. but its not to early. it will get swapped in 2 months. just trying to get as much info as i can so i dont run into problems when im in the process. help if you can guys! thanks!
Anthony
Old Dec 11, 2007 | 02:49 PM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
i just got done swapping out my old 305 tpi for anice 350 4 bolt main and its not a hard swap to go from fuel injected to carb but thats just my opinion
Old Dec 11, 2007 | 06:37 PM
Drone358's Avatar
alright.. well how did you deal with the computer?? And im wanting to install new gauges also.. And i want to keep the turn key on the steering column to start.. still need some more info and deeper details.. In the process now.. Thanks Guys!
Tyler
Old Dec 11, 2007 | 08:14 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Anthony
same starter for sure and i'm pretty sure the flywheels are interchangeable as well...the linkage can be found at most junkyards relatively cheap..
five7kid's Avatar
Transmission: 4L80E/4L80E
Take out the wiring and sensors associated with the computer and leave everything else. As has been discussed many, many times here, that can be done without cutting a single strand of copper.
With what is left, everything else will work - starter, gages, alternator, etc.
Old Dec 22, 2007 | 07:40 PM
jean's Avatar
I'm in the process of cleaning also my engine bay as this 85 transam got rid of the LG4 and have an old carb 355 now but having hard time with all that messy harness stuff, looks like everything is inter-connected... unpluged everything from driver's side ECM ... but then have wires from ECM going down to the starter..?? ( should I take them of ? ) and also other wires running seems under the car trans lock-up maybe , or in the dash???) Also wanna keep the wires for engine temp and oil pressure as some aftermarket gauges had been hooked and orinla wires are somewhere in the engine bay...
HELP!!! thanksss! How can't I find any pictures of that process step by step ???
Old Dec 24, 2007 | 02:33 PM
cainestl's Avatar
Car: 1985 Trans Am
Re: Swapped 85 tpi transam 305 to 87firebird 350 and need help
I have a 85 transam and just dropped a 87 firebird crate engine in it. She runs good except for when I ride street for more than 15min then she gets up to 220-235 degrees on the dash. I have a new stock radiator,185degree therm, Im not loosin coolant and i just got the system flushed.Do you think the water pump is to blame? Also what parts do you recommend me to change from the stock 305 to better benefiit and upgrade the performance of the new 350. I heard I need to change the 305 fuel injectors to 350 fuel injectors. Is this Correct? Please any help is highly appreciated.
Caine
Old Dec 24, 2007 | 02:41 PM
lonman89's Avatar
also if you wanted higher compression you could use the 305 heads on the 350
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
draco
Oct 4, 2015 09:25 PM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
