Throttle Cable Bracket
Old Dec 13, 2007 | 08:59 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
So I am just about to get my car running but I have not found a clean throttle cable bracket yet.
I have a 82 Z28 that had a 305 carb motor in it. I installed a 383 vortec motor and my throttle cable bracket will not work. I have a manual trans and cruise control with a holley carb.
Anyone have a picture of a clean throttle bracket or know how makes one?
Old Dec 13, 2007 | 09:45 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Throttle Cable Bracket
You've got what intake and carb now?
Your factory bracket is for a quadrajet. Since your new engine and your old engine are the same dimensions, the only reason it wouldn't work is if you are running a holley on a single plane intake or something along those lines. In that case you will need an aftermarket bracket from Summit or Jeg's or someplace that sells aftermarket stuff.
Old Dec 14, 2007 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm running a Holley 600 on a dual plane. I used the original Q-jet set-up (cruise included. By the way, if you dumped the computer, you'll need to reground the cruise for it to function) though I may have modified it. Sorry, the old brain isn't what it once was.
JamesC
Old Dec 14, 2007 | 07:37 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Yeah, I think you can make it bolt on, the problem is that the cable doesn't hook to the throttle stud on the carb at the same spot on both carbs. You may not get full throttle or low idle depending on which way the throttle bracket is off.
Old Dec 14, 2007 | 11:11 AM
Comp788's Avatar
I am running a holley 800 cfm carb.
The vortec heads use intake bolts that mount straight up and the conventional heads are at an angle. That is where the problem is.
I was just avoiding trying to make a braket from scratch.
Old Dec 14, 2007 | 11:32 AM
JamesC's Avatar
I no doubt modded the OE piece, which works fine with both the carb and the Vortecs (Just don't recall exactly what I did).
JamesC
Old Dec 14, 2007 | 02:53 PM
Comp788's Avatar
James,
Could you take a picture with your air cleaner off?
Any other picture would be appreciated too.
Old Dec 14, 2007 | 03:02 PM
JamesC's Avatar
Originally Posted by Comp788
James, Could you take a picture with your air cleaner off? Any other picture would be appreciated too.
I'll try to snap something in the next few days (ice/snow here). You can check my "car details" below for some pics.
JamesC
Old Dec 15, 2007 | 02:48 PM
JamesC's Avatar
Hey, Comp,
I was going to e-mail you five pics as attachments, but... Anyway, here are three (take special note of the first one):
Attached Thumbnails Throttle Cable Bracket-100_1950.jpg   Throttle Cable Bracket-100_1951.jpg   Throttle Cable Bracket-100_1952.jpg
Old Dec 15, 2007 | 05:17 PM
Comp788's Avatar
James.
Thanks!
Old Dec 15, 2007 | 09:35 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
I don't have any pics but, Edelbrock makes a nice bracket for the vortec setup
Old Dec 17, 2007 | 05:35 AM
JamesC's Avatar
Interesting. I searched but found nothing. Do you have a part number?
JamesC
Old Dec 23, 2007 | 01:07 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
http://store.summitracing.com/partde...216+4294865279
Old Dec 23, 2007 | 06:56 AM
JamesC's Avatar
Comp is running a manual transmission.
JamesC
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Kenwood
Sep 4, 2015 05:50 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
