is this a L98?
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
is this a L98?
1st i don't know if this is the correct section to be posting....
anyways i am thinking about buying a engine but the owner dosn't know much about. he says he pulled it from a camaro but dosn't know the year. all he knows it is a 350. the block casting he have sent me where 14093638. i did do some reserch and it looks like it is a TPI motor that looks to be 87-95. my guestion is "is this a L98?" is this the one w/ 250Hp and 345Lb tq? thanks any help would be great!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: is this a L98?
We need the specs off the heads, as the blocks could be used in trucks or other cars.
The 350 TPI iron heads would have part number 14101083.
Transmission: 4L80E/4L80E
All the more reason for you to check the head casting #'s.
Wouldn't hurt to take a gander at the lifter valley, either.
It could be a '93-up truck or crate engine.
My 638 block started off life as a ZZ3 crate engine. They were also used in LO5's, which in trucks didn't have roller lifters.
So, the block casting # tells you a 350, but doesn't tell you much beyond that.
