305 TBI to Carbed 350 swap. How difficult?
Old Jan 22, 2008 | 07:34 PM
red89camaroRS's Avatar
Car: 1989 Camaro
Engine: 305 TBI
Transmission: Built 700r4
HI I have a 305 TBI in an 89 Camaro. I want to do a 350 Carbed swap. How much is this going to cost and how difficult is it? I'm trying to do away with as much electrical as possible So i will more than likely go with an MSD. Also, as far as the gauges go, are they manual or no? what else will i need to change?
Thanks.
Old Jan 22, 2008 | 10:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Go to the thirdgen.org homepage, click on the link on the left called "Tech Articles". Look for one that discusses swapping from EFI to carb. Look at the parts listed, check summitracing.com or jegs.com or similar sources for prices. The article pretty well describes the process, the difficulty will depend entirely upon your abilities.
The gages are electrical. No, they don't go through the computer.
With a TH700R-4, you'll have to provide for proper geometry for the throttle valve cable (corrector bracket attached to the carb throttle arm), and provide means for the torque converter lock-up. Failure to do either of these properly will result in a burned-up transmission.
Old Jan 22, 2008 | 10:26 PM
Car: 1989 Camaro
Engine: 305 TBI
Re: 305 TBI to Carbed 350 swap. How difficult?
Thanks.
Old Jan 25, 2008 | 12:52 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
I agree about the TV cable, but as for converter lock-up..... It's electronic lock-up, and will decrease gas mileage. It has had no other affect on my car in about 23,000 miles. It's a 1-2 MPG difference, so it is worth hooking up.
As a side note.... remember the ground wire on the back of the passenger side head. It caused me a lot of headaches, cause of a bad ground for the speedo. I did the same swap in a 91 firebird.
Old Jan 25, 2008 | 02:07 PM
five7kid's Avatar
TCC lock-up is more than fuel economy - without it, you'll burn up your 3-4 clutch pack. Might not notice it during "normal" driving, but when the tranny won't shift 2-3 WOT, you'll wish you would have listened.
Old Jan 26, 2008 | 05:36 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I'm in the process right now of building a smallblock 350. I have a 350 4 bolt main bored .060 over with vortec heads reaching 400 horsepower. Will it affect the steering at all with less vaccum at low rpms? The cams powerband starts at 2000 rpms so how will that affect the brakes? Are their any interior compenents that wont work? Will the car feel loose?
And how much power will the 700r4 hold with a TC lockup kit? where can i get one?
The motor is almost completely built, i should have it ready to swap in a week or two.
Old Jan 30, 2008 | 04:26 AM
jdhogg86's Avatar
I've got a built LT1 that only pulls about 10-12" of vacuum at idle. Brakes fine when you stop, can creep a little at a light.
For the TCC, my friend and I pulled the crossfire inj off his trans am (went to a carb w/o computer). Disconnected everything but power to the ecm, wiring to trans and took out the check engine bulb-trans worked great.
Steering isn't based on engine vacuum, just brakes.
Old Jan 30, 2008 | 01:25 PM
five7kid's Avatar
TH700R-4 (1983), or TH200C (1982 or 1983)?
The TH200C won't care. The TH700R-4 will.
Old Jan 30, 2008 | 04:45 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I thought the torque converter was locked when manually shifting from 1-2-D. So can't you do that instead of buying a TCC? and where can you get one?
Old Jan 30, 2008 | 05:37 PM
five7kid's Avatar
The TCC lock-up is electrical, not mechanical. Controlled by the computer (non-computer Canadian I'm not sure about).
Old Jan 31, 2008 | 10:41 AM
doc221978's Avatar
Car: '81 Z-28
You can get a TCC from summit racing. I was looking into all of this.... my car has never went from 2-3 at WOT. five7kid is right about it burning the clutch packs. Mine were just already toast. (Thank you for the info)
As for the vortec engine, steering should be fine. brakes will depend a lot on the cam. I have a comp cams xr 282 hr, and i pull about 15 in on a 355. The car should feel the same, except more power.
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 1, 2008 | 07:09 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can also get alot more brake by adjusting timing some, and then adjusting carb for the timing - I did this on my 350 swap with a mild cam. In addition, you can rig a vacuum canister into the system that will hold vacuum to asist with low vacuum brake issues.
I've seen where alot of folks rig the TCC lockup function to a manual switch - I'm guessing that they leave power to the ECM, leave wiring to the 700R4 intact, and they utilize a switch wired off the diag port under the steering wheel. I had to rebuild my tranny anyway (it was slipping, but couldn't tell until the 350 power was in front of it), so I just installed a vacuum-controlled TCC lockup kit in the tranny.
The really important part is correcting the geometry at the throttle cable/TV cable assembly - an improper geometry of the TV cable will fry the tranny quick!
Old Feb 5, 2008 | 10:55 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Will the stock radiator keep my 350 bored .60 over cool enough to drive around on a hot summer day? What about the temperature fan switch and all the other switches? Do they run off the ecm?
And does anybody make a bracket for the throttle valve cable?
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
