hp estimate plz
Old Feb 10, 2008 | 02:02 AM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
hp estimate plz
i jsut swapped from a v6 to a 383 stroker... it is 13:1 with all froged internals 64cc fully port and polished aluminum heads with a 2.02 and 1.600 valves erson race springs 230/230.480.480 erson cam, 1.51 ERSON FORGED ALUMINUM ROLLER ROCKERs, crosswind intake, 750 edelbrock carb, 120gph electric fuel pump full msd ignition, 6AL box, blaster 2 coil, and distributor, march underdrive pulleys and hedmen headers
Old Feb 10, 2008 | 09:55 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: hp estimate plz
13:1? What fuel do you plan on putting through it? The camshaft is way to small for that much compression.
Old Feb 10, 2008 | 11:17 AM
chaoz28's Avatar
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
Re: hp estimate plz
ive read nothing but bad news on those erson cams as well plus the grind on that cam is for street driving.. do youself a favor and put something that can handle that muhc and produce to compliment it.. comps 280h "magnum" would work well with that set up
Old Feb 10, 2008 | 03:16 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: hp estimate plz
ya its gotta run cam2 in it and for the cam setup i bought it in the very begining to get started and didnt realize i was gonna run 13:1 so thanks for the advice on that. any other advice? this is my first real engine build/swap so any advice would be very much appreciated, what kind of a lift do you guys think i should go with for it.
Old Feb 10, 2008 | 04:25 PM
chaoz28's Avatar
Engine: 355/2.1
Re: hp estimate plz
oh .. err well if thats the case finish your engine (with a decent cam and tranny behind it and decent rear gears id give you around 400hp to the wheels)
but go look around at teh other 383 posts.. and look for my comments on them.. suspension is the first thing u need to worry about or youll tear your car apart. i have siad it a few times around here l8ely you shouldt have a problem finding it
Old Feb 10, 2008 | 09:15 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: hp estimate plz
haha i know about the suspension the only thing i need now are the lcas and panhard rod. i fabbed up my own sub frame connectors similar to the umi ones but they r full bolt in so it ties in to the trans crossmember. and i got the steering brace/front frame support, and strut tower brace. so im pretty set up and thanks for all the help its appreciated. from what i have right now what would you upgrade to get a few more poneys
Old Feb 10, 2008 | 10:32 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
Re: hp estimate plz
i agree
Old Feb 10, 2008 | 11:27 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: hp estimate plz
how big of a lift do u suggest then
Old Feb 11, 2008 | 12:00 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: hp estimate plz
you need more duration to bleed off some pressure. higher compression will generate alot of cylinder pressure if you dont bleed some off with more duration and overlap.
i'm not to familar with flat tappet cams, i'm a roller guy, but something in them mid 240's duration range would be nice. And as much lift as you can get since your heads probly peak flow in the .500-.600 range. Still have to run a high octane gas...race gas or maybe E85 if you get it tuned on that
Old Feb 11, 2008 | 05:12 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: hp estimate plz
ok ya im runnin 110 cam 2. im setup for a .500 lift do u think i should get a new valvtrain and bump it up to somwhere in the .500 or maybe even .600 range
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
inferno15
Aug 29, 2015 01:48 AM
