Help on block Numbers....
Old Mar 1, 2008 | 08:24 PM
92 CaMaRo Rs's Avatar
Hey people i got a question about the block i jus baught.
Id like to know everything bout this block the stroke all that.
heres #'s
3956618
19b400087
TO6I9HD
thats all #'S i think.
thank for ur help.
Old Mar 1, 2008 | 08:35 PM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
Re: Help on block Numbers....
http://www.mortec.com/castnum.htm
3956618....302.....69....4...Z-28 Camaro
3956618....327...68-69...2
3956618....350.....69....2 or 4
http://www.73-87.com/chevy_ids/scode5.htm
Year 1969
Suffix HD
CID 350
Appl Turbo Hydro
Carb 2BBL
Body A, F, X
Old Mar 1, 2008 | 08:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's a 4" bore block. The best way to figure out the stroke is to measure it.
Old Mar 1, 2008 | 08:43 PM
It is a 2 bolt main
so it is 327 right?
Old Mar 1, 2008 | 08:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not necessarily.
Old Mar 1, 2008 | 08:49 PM
Im sure its year 69.
He said it was 350 up there?
Old Mar 1, 2008 | 08:52 PM
Car: 83 Camaro
Axle/Gears: 342's
I also tried the engine serial on another camaro site, my guess would be a A or X body car. The block may be worth more to a restorer than you paid for it.
Old Mar 1, 2008 | 08:55 PM
Originally Posted by jvontungeln
I also tried the engine serial on another camaro sight, my guess would be a A or X body car. The block may be worth more to a restorer than you paid for it.
Well right now i have a 327 with no main caps (worthless) was gonna restore but then i baught this one for like nothing and im restoring no matter what i was hoping 327 tho but its all good 350 is better
Old Mar 1, 2008 | 09:00 PM
Car: 83 Camaro
Axle/Gears: 342's
Just saying that you could most likely make money selling it to someone trying to build a numbers car from '69.
Old Mar 1, 2008 | 09:04 PM
Naw ima put it in my 92 camaro build it up nice to i jus wanted to know everything bout it so is it 350 or 327?
Old Mar 1, 2008 | 09:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It could be either, you'll have to inspect it to find out. It's almost 40 years old, who knows what might have been done to it since it left the factory.
Old Mar 1, 2008 | 09:10 PM
Car: 83 Camaro
Axle/Gears: 342's
The #'s say it was built as a 350, check the stroke on the crank to make sure.
Old Mar 1, 2008 | 09:12 PM
Its going to machine shop Monday so im sure ill find out then Gonna be a nice build.
Old Mar 1, 2008 | 09:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
TO6I9HD
T = Tonawanda engine plant
0619 = June 19
HD = 1965 327 out of a full size car
HD = 1966 327 from a Vette
HD = 1969 350 from an A, F, or X body.
19b400087 should be the last part of the VIN number from the original vehicle.
1 = Chevrolet
9 = 1969
B = Baltimore assembly line
400087 = Sequential number. Number 87 in the production run in that year for the car style it was in.
Looks like you have a 1969 350. It was originally rated a 250 hp with a 2 bbl and had a TH350 behind it.
Old Mar 2, 2008 | 08:51 AM
Well looks like ill be building one hell of a 350 with a 700r4 behind it lol ty guys alot ill be sure to get pics when it is back from machine shop.
Stuck with a 327 out of a 67 camaro with no main caps lol I dont know what ima do with it.
Old Mar 2, 2008 | 10:23 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Buy new main caps and get it line honed. Is it really worth it? It's just another 4" bore block. The crank is what makes it a 327.
Old Mar 2, 2008 | 10:44 AM
Yea it will be in the shop..wrapped up until i get somthing to put it in.
I will be getting the 350 built aluminum heads intake 4 bbl all that =)
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
