s10 into 355 need help BAD
i got a 91 350 block with 99 vortec heads ported out... got the motor put together and started it up for about two minutes then i cut it off ok..... and then my push rods got bent up and some of them snaped...any ideas what i can do?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: s10 into 355 need help BAD
Sounds like the valves hit the pistons or the rockers are not designed for extra lift. Tear it down, rebuild it and check all the clearances properly. Pushrods don't bend unless something gets hit. When you mismatch parts, clearances and fitment all need to be checked.
Car: 87 IROC L98
If the valves hit the pistons, they're probably also bent.
did you have the headsd worked for the lift of the cam?
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
List your specs and what you did to the heads.
If you run 1.6 rockers you have enlargen the pushrod holes in the head.
Also if your running a cam over .480 lift, you have to machine down the valve guides. Or the rockers will hit.
Transmission: 4L80E/4L80E
Hotrodboba400
Dec 10, 2019 07:07 PM
Billy Decker
Sep 4, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
