95 350
Old Apr 16, 2008 | 12:48 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
95 350
Im looking into buying a 95 350 with 80k miles. Its been wrapped up and sitting on an engine stand for 3 years. I dont have the casting numbers but i was wondering if this year motor came with decent factory cylinder heads?
Old Apr 16, 2008 | 01:26 AM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Re: 95 350
Do you know what it came out of. A truck? If so the trucks still had TBI in 95. Heads probably aren't anything speical. Also may have a flat tappet cam. In 96 the trucks went to vortec heads and a roller cam.
Old Apr 16, 2008 | 02:19 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: 95 350
I believe it was out of a truck. I will probably just put headers on it and thats it for now. Cause its still gonna be more power than what im use to lol. I was planning on just putting a new intake manifold on and making it a carbed motor. How bad are the flat tappet cams?
Old Apr 16, 2008 | 02:35 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: 95 350
bump
Old Apr 16, 2008 | 06:01 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: 95 350
It's not that flat tappet cams are bad. Rollers are more desireable though because they have a broader torque curve and better mileage. As for the heads, it depends on the casting number. This should show you what the engine and heads are from.
http://www.mortec.com/castnum.htm
If you find out what heads they are, I might be able to tell you a little more.
Old Apr 17, 2008 | 01:44 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: 95 350
I dont have the casting numbers but im thinking the top end most be pretty restrictive. the 1995 350's were only rated at 210 horse. so im def gonna have to get some new heads. I wanna be up over 300 horse.
Old Apr 17, 2008 | 04:13 AM
doc221978's Avatar
Car: '81 Z-28
Re: 95 350
Vortec heads, and a LT1 cam should put it over 300hp. Some of the flat tappet blocks from the time had provisions for a rolloer cam. You can find a lot of the parts cheap on ebay. Summit and jegs have some good prices to. If it's a roller, another good cam choice is the comp xr252. Good mileage, and enough torque for stoplight to stoplight, but it's not that good higher up. The power falls off quick, but it even works well with 2.73 gears.
Old Apr 17, 2008 | 04:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it's from a truck or full size passenger car, it has swirl port heads. You can get 300 HP out of them, but it's a bit of a task. Passenger car would have roller lifters.
If it came out of an F-body or Vette, it will be an LT1, in which case it should be installed as an LT1.
Old Apr 17, 2008 | 04:40 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: 95 350
Im thinking its out of a truck, the guy was gonna use it as a replacement for his truck, i know thats not a gurantee.
Old Apr 18, 2008 | 08:36 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: 95 350
Ok got the motor today. Seems to have good compression we could barely budge the harmonic balancer untill we took afew plugs out. the numbers on the heads is 14102193. I looked it up and it said used on 87 and up 305/350. 1.94''/ 1.5 valves. Since they were also used on 305's im thinking i should get rid of the them or atleast tear them down and clean them. the majority of the ports were closed off and the motor was wrapped in plastic but from looking inside the heads it looks alil dirty.
Old Apr 19, 2008 | 12:00 AM
five7kid's Avatar
193 heads are swirl ports. They're okay for a low-RPM engine, just depends what you're looking for whether or not to use them.
Old Apr 19, 2008 | 01:02 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Re: 95 350
I want to be up past 300 horse. Mostly city miles and max rpm at about 5500 rpm.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
