502 ramjet
Old Apr 21, 2008 | 08:28 AM
ohhyea89iroc's Avatar
502 ramjet
can i put a 502 ramjet in my 86 iroc?
Old Apr 21, 2008 | 12:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
Old Apr 21, 2008 | 01:06 PM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Re: 502 ramjet
You might want to beef up your tranny, rear end, brakes, and sub frame while your at it. Those engines pack a good punch!
Old Apr 22, 2008 | 07:56 AM
Re: 502 ramjet
so a my 700r4 tranny would hook up to a 502 or would i need a diff bell housing.
Old Apr 22, 2008 | 08:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 502 ramjet
A 502 is no different than any other short deck BBC swap.
Read this
https://www.thirdgen.org/forums/engi...swap-info.html
Old Apr 23, 2008 | 11:45 AM
sngreen's Avatar
Car: 1984 Z28
Engine: 468 Ci
Transmission: T-5 (Until it breaks)
Axle/Gears: 3.73 posi
Re: 502 ramjet
it will bolt right up, but you will turn the 700r4 into pices the first time you really stab the gas!!! (GOT TO LOVE A RAT MOTOR!!!!)
Old Apr 23, 2008 | 08:45 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: 502 ramjet
no need to bolt the 700r4 up to that 502 although yea it would fit but you would have to pull it out and replace it no sooner than you got it in.
Old Apr 27, 2008 | 02:54 PM
Re: 502 ramjet
so what kind of tranny would i need?
Old Apr 27, 2008 | 06:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 502 ramjet
A TH400 would be the first recommendation.
Old Apr 28, 2008 | 08:17 AM
Re: 502 ramjet
so a th400 would hold the power. ok what type of converter should i get like a 2500 or a 3000.
Old Apr 28, 2008 | 12:15 PM
five7kid's Avatar
2500 would be adequate for most usages. What do you plan to do with the car?
Old May 2, 2008 | 08:18 AM
Re: 502 ramjet
street/ drag car, a sleeper car
Old May 4, 2008 | 11:09 PM
five7kid's Avatar
It's a little difficult to hide a 502 Ram Jet in a 3rd gen.
Old May 30, 2008 | 04:53 PM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Re: 502 ramjet
I bought a 502 ram jet to put in a 91 trans am, I was thinking about supercharging the zz383 but I have change my mind Anyhow, I know that I will not have trouble to fit the engine (exept the hood), I was planning on do some mods that I want to ask you people for the make the right mod.
1) 8 point Roll cage (but I need to get in and out easily from the car) (compettition engineering or spohn)
2) Which housing for the rear end? Which is better for street and track (4.11, 3.90, 3.73, I want to accelerate fast)(moser 9" or compettition engineering
3) K member or not to K member
4) TKO-600 but where is the best place to get it?
5)I will swap rear drums to disks, should I change my master cylinder? I will use wilwood 12.6" setup.
6) I have spohn sub frames, lower control arms, wonder bar, and torque arm, should I replace them with an other brand or should are they(spohn) reliable?
7) I have tokiko struts and moog springs when I put the 502, do I need to replace the front springs??
Only these questions come to my mind for now
Thank you for your time...
The Tank
Aug 30, 2015 06:16 PM
Jester
Carburetors
Dec 13, 2001 09:08 PM
502z28
Nov 25, 2001 04:45 AM
89rsvert
Oct 12, 2001 05:53 PM
