TBI to TPI
Old May 13, 2008 | 09:05 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
TBI to TPI
Well, i may be getting ahold of an 89' RS with an LB9 in it on sunday.. Will be the home for my L98 TPI once i get the car (if i do).
My luck, the LB9's in 89 RS's are TBI.. i was hoping it was TPI so my L98 would slap right in there.. of course not!
Well, obviously i need the engine harness, MAF sensor, and the intake setup (already have it)
But heres what i need to know.. Are the dash harness's the same, or do i need one from a TPI car? Along with the ECU.. are they the same just with a different prom.. or do i need a whole TPI ECM?
Appreciate the help guys,
Old May 14, 2008 | 08:23 PM
Engine: THREEFIDDY!
Re: TBI to TPI
lol no one eh??
Old May 15, 2008 | 08:42 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: TBI to TPI
Originally Posted by thesargster4
Well, i may be getting ahold of an 89' RS with an LB9 in it on sunday.. Will be the home for my L98 TPI once i get the car (if i do)....
Congrats on the new purchase, if you get ahold of it, that is....
An LB9 is just that, a 305-TPI. If it were a 305-TBI, it would be designated an LO3. Who is telling you it's an LB9, the seller? Easiest way (aside from lifting the hood) to tell would be by the VIN number. Do you know it yet....?
Well, obviously i need the engine harness, MAF sensor, and the intake setup (already have it). But heres what i need to know.. Are the dash harness's the same, or do i need one from a TPI car? Along with the ECU.. are they the same just with a different prom.. or do i need a whole TPI ECM?
... so now your sure that it's TBI then? If it's an LB9, it's Tuned Port Injected, and the only thing you'll need to swap over to the L98 is the PROM, and fuel injectors. If it turns out to be an LO3, which is more than likely what it is, you'll need the entire TPI setup, including the fuel pump. Here's a quick list of what you would need for that particular swap, Click Here....
Old May 15, 2008 | 09:12 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: TBI to TPI
Seems like a lot of work...why not just buy a TPI...
Old May 15, 2008 | 11:59 AM
Engine: THREEFIDDY!
Re: TBI to TPI
Sorry, it is a LO3.
I kno for a fact its TBI.. and i do have the complete TPI setup, im just missing the engine harness and MAF sensor. I'll read your page, im just hoping the TBI dash harness is the same!
Also, the post says i need a TPI ECM.. is it possible to use the same ECM and just swap the prom? Or is it completely different?
John
Last edited by thesargster4; May 15, 2008 at 12:01 PM. Reason: Automerged Doublepost
Old May 15, 2008 | 12:37 PM
Re: TBI to TPI
No, completely different ECM John (you can grab one for pretty cheap though)....
Old May 15, 2008 | 03:06 PM
Engine: THREEFIDDY!
Re: TBI to TPI
Yeap, just found a rebuilt one on the bay for $80.. doesnt have a prom tho, im thinkin i wanna throw a thermomaster in it.. hopefully someone here on tgo has one for sale!
Found out the dash harness is the same, which is a plus.. so now i have to find my engine harness, and ill be good!
How about the distributor.. same thing or diff?
Old May 15, 2008 | 03:27 PM
Re: TBI to TPI
The dizzy is the same....
What kind of ECM did you come across, and did you buy it yet? If not, look into going with a speed density ECM '7730 (91-92 TPI). Rather than waste money on an engine harness, you could repin the existing harness to accept Tuned Port Injection w/SD. Click the link....;
https://www.thirdgen.org/forums/tpi/...inning+harness
Edit: Actually, you know what, scratch that. If your targeting the '165 MAF ECM, stick w/it then, as things are going very smooth for you, and I don't want to disturb the flow of your build by throwing in alternatives....
Old May 26, 2008 | 02:46 PM
cwhitey's Avatar
Re: TBI to TPI
If you go to www.hawksthirdgenparts.com/ you can get a whole 350TPI for i believ its 1200-1600 and it says "Camaro/Firebird 82-92 350 TPI Engine with wiring harness, computer and accessories. We guarantee that these motors will run but we do not guarantee lengths of time due to the fact we do not know how they will be driven.. Mileage varies from 100,000-160,000 miles. Call for availability and shipping quotes" so look into that if you want i know i was going to do that to replace my L03 but i decided to turn it into a 335 Stroker.
Old May 27, 2008 | 12:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by cwhitey
If you go to www.hawksthirdgenparts.com/ you can get a whole 350TPI for i believ its 1200-1600 ... i was going to do that to replace my L03 but i decided to turn it into a 335 Stroker.
Sorry to hear that.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
