rear main seals
Old May 16, 2008 | 05:30 PM
wayfastf150's Avatar
rear main seals
I just bought a 350 for real cheap, it has a 2 piece rear main seal with a different crank end than my 305 tpi has. Can I put my 1 piece rear main seal with my crank from the 305 into the 350 so I can use the old starter and flywheel?
Old May 16, 2008 | 08:54 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: rear main seals
I don't no all the specific reasons but I am 99.99 percent sure you can not use it
Old May 18, 2008 | 12:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've seen adapters to put 2-piece rear main seal cranks in 1-piece rear main seal blocks, but not the other way around.
You can buy a new crank for less that it costs to adapt. Just get a 2-piece rear main seal flywheel (flexplate if auto tranny) for '83-'85 application, and you can use your old starter. That's the cheapest route, and when you get right down to it, the "right" way to do it.
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
